Home > Maintenance & Mods (L322) > Rusting upper tailgate - on the horns of a dilemma. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8530 |
the rust comes from the inside of the tailgate, so any blasting type stripping won't deal with it properly. it may be the case that you could have a second had one acid dipped which would get rid of any rust on it even the stuff inside i reckon (but probably best to ask the strpper to check that it will)
3rd Apr 2017 4:34pm |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 |
I had this years ago on my 2004. The workshop I used said the same as yours, they couldn't guarantee how long the repair would last. But they cleaned out and sealed as good as they could. When I sold the car five years later, there was no indication of new rust. ----------
3rd Apr 2017 4:38pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
I am currently debating the same dilemma. I have some experience having worked in a bodyshop about 15 years ago. The reason rust will reappear is once the process of rusting has started it must be "killed" off.
3rd Apr 2017 4:54pm |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
I have the same problem and even though the dealer inspected the car just before it was 6 years old and found no corrosion, they are now quoting £2300 to fix because it was a couple of weeks out of warranty.
4th Apr 2017 7:59am |
neilw Member Since: 20 Aug 2014 Location: Devon Posts: 39 |
Glad I'm not the only one facing this issue. My 2008 has the same symptoms. Currently looking at taking it to a couple of local body shops for quotes as the bottom edge is going and there's a set of three small blisters a couple of inches above the edge |
4th Apr 2017 1:00pm |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
Had mine done a couple of years ago cost was about £250 and it's still fine.
4th Apr 2017 1:37pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 |
I've had paint bubbling on the metal beside the back of the rear wheel arches, both sides. Stone chips get thrown at the edges of the wheel arch, the paint gets perforated and the corrosion spreads. On the Discovery, Evoque etc there is plastic cladding to prevent this, but presumably as the RR is "luxury" there is nothing, fine in Dubai, Western Australia, Arizona etc but poor in the UK. The P38 was galvanised, then had anti-chip paint and then undercoat and top coat. That was stopped for the 322, which just has paint. Earlier cars seem to be better than later ones, I don't know whether that is due to poorer steel with higher scrap content, poorer paint due to rule changes designed to protect the environment or for some other reason. Whatever it is, it is disappointing, especially at the prices 322s were when new.
4th Apr 2017 5:09pm |
ruffy Member Since: 11 Jan 2016 Location: North Yorkshire Posts: 70 |
Thanks all for your replies. I have decided to wait until the rust breaks through the paint and then replace the tailgate with a new one, which should buy me a few months. 1982 SIII 88β diesel
4th Apr 2017 6:45pm |
Tom Heath Member Since: 19 Mar 2017 Location: Telford Posts: 103 |
Having had a number of british and american classic cars over the past 20 years, I can guarantee that once rust gets inside a seam, which is in a damp environment, there's not a huge amount you can do. Having done bodyworkon a friend's Mustang which had been dipped and e-coated, the acid doesn't get into the seam. The only solution is to split the seam where possible and weld in new metal.
4th Apr 2017 6:52pm |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 |
ruffy, have you had much luck with this? I have noticed some paint bubbling on mine too and wondering if I can use some kind of treatment to avoid it getting worse.. Current:
29th May 2017 7:58pm |
I haven't done anything with it, other than periodic application of rust treatment underneath the seam that runs along the inside lower edge of the tailgate. I am going to wait until the rust breaks through the paint and then replace the whole upper tailgate. At the moment there is some bubbling under the paint but no rust spots. 1982 SIII 88β diesel
30th May 2017 11:23am |
I was thinking the same.. did you use the likes of waxoyl/dinitrol or some sort of rust prevention spray? I assume you apply it from the voids at each end? Current:
30th May 2017 12:28pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2653 |
I pumped a whole load of this into the tailgate, can't hurt:
30th May 2017 1:15pm |
