Home > Maintenance & Mods (L322) > Replacing shock absorbers on 2011 4.4 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8503 |
can't see the point, they bolt on, and are no where near the springs.
17th May 2018 4:10pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
It's in case you let the axle drop as you will tear the rubber spring. Just make sure you support it and it should be fine. |
17th May 2018 4:44pm |
Peters52 Member Since: 06 May 2018 Location: County Durham Posts: 5 |
Many thanks, it’s a relief to get a second opinion. I’m changing them because they came up as an advisory on the MOT and the car feels ‘bouncy’ at the back - hope this does the trick as they ain’t cheap! |
20th May 2018 7:53pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
21st May 2018 7:58am |
