![]() | Home > Technical (L322) > Air Suspenion Issue |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
Paul,
Paul1234002 Member Since: 06 Oct 2015 Location: Manchester Posts: 32 ![]() ![]() ![]() |
Simon,
Alistarh,
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3660 ![]() ![]() |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Paul1234 . not sure about your diagnostic but most can read resovoir pressure.. the scorings not noticeable in the chamber.. |
Alistar, There was no scoring at all.
An ffrr (L322) is like a baby... it will often spit out its' dummy for no reason, and when there is something wrong, it doesn't always have the correct vocabulary to convey the problem.....
Paul,
Buddy if your EAS is working when you've reset the system, with out fault, then it's not the EAS system that's causing the message in the first place... plugging in your box of tricks doesn't magically repair worn out components.. Your obviously new to Range Rovers, and haven't gotten used to their quirks... the biggest problem is the all singing and dancing computer is actually stupid, and lacks the messages to convey the real problem, so it has a panic throws up no end of faults, the new owner spends thousands of pounds on new parts only to discover that there is still a problem.. eventually you will get to the route cause..
Thank you all for your guidance and wisdom.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
If you are lucky the relay will come with it!
http://www.ebay.co.uk/itm/LAND-ROVER-RANGE...3641.l6368
New air compressor & Relay turned up today. Fitted and all is well.
