Home > Technical (L322) > Air Suspenion Issue
Page 3 of 3 <123
alistairh
Glad to hear it's resolved Thumbs Up
Post #427908 15th Feb 2017 6:28pm
recovereruk
England 2006 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Eas problem
Hi just reading your post and had a thought the crystals that you replaced are there to stop water ingress into the system seeing as you said it happened on frosty mornings I would say you have water in the system which may be freezing or have corroded internal workings giving you your fault just a thought you may have cured the problem but still have the fault because you haven't purged the system of contaminants hope this helps .
Post #427921 15th Feb 2017 7:26pm
Page 3 of 3 <123
