![]() | Home > Technical (L405) > Soft close tailgate or clunk and bounce |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35621 ![]() ![]() |
from the owners manual,
i edited my post after reading the OM... |
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 491 ![]() ![]() ![]() |
I think they are saying it isn’t part of the vogue spec. How can I go back to them and say it is? 2017 Range Rover Vogue V6 Diesel
depends what you mean re 'slamming shut'.....get them to open/close some tailgates on their forecourt and see if its anything like yours.. ... - .- -.
yes, I did and it did the soft close! they are saying mine does it so minutely you cannot see it happen!! 2017 Range Rover Vogue V6 Diesel
in the pdf i supplied in an earlier post it mentions this,
Thanks Stan. Does the extract say it is all L405 variants? They will say that it is Vogue SE and above or somtheing stupid! 2017 Range Rover Vogue V6 Diesel
so it looks like one of the boot struts is being replaced. I guess that might slow the closure speed of the tailgate.
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Hi
Mine all works properly now. It was all about the alignment which required the hinges to be moved about until the doors closed with the soft close. Had to go to the body shop as the garage couldn't do it. 2017 Range Rover Vogue V6 Diesel
Thanks Jase |
