Home > Technical (L405) > Soft close tailgate or clunk and bounce
from the owners manual,
Post #523822 5th Aug 2019 2:29pm
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
Thanks Stan. But shouldn’t it make the second click sound after closes? Mine just slams shut 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #523824 5th Aug 2019 2:34pm
i edited my post after reading the OM... Mr. Green ... - .- -.
Post #523825 5th Aug 2019 2:35pm
Jase71
I think they are saying it isn’t part of the vogue spec. How can I go back to them and say it is? 2017 Range Rover Vogue V6 Diesel
Post #523826 5th Aug 2019 2:35pm
depends what you mean re 'slamming shut'.....get them to open/close some tailgates on their forecourt and see if its anything like yours.. ... - .- -.
Post #523828 5th Aug 2019 2:40pm
Jase71
yes, I did and it did the soft close! they are saying mine does it so minutely you cannot see it happen!! 2017 Range Rover Vogue V6 Diesel
Post #523829 5th Aug 2019 2:41pm
in the pdf i supplied in an earlier post it mentions this,
Check the software level of the tailgate control module (upper) and ensure it is the latest released version - if it is not, update the module
worth checking ? ... - .- -.
Post #523831 5th Aug 2019 2:47pm
Jase71
Thanks Stan. Does the extract say it is all L405 variants? They will say that it is Vogue SE and above or somtheing stupid! 2017 Range Rover Vogue V6 Diesel
Post #523832 5th Aug 2019 2:49pm
Jase71
so it looks like one of the boot struts is being replaced. I guess that might slow the closure speed of the tailgate.
Soft close works if I close it slowly by hand. 2017 Range Rover Vogue V6 Diesel
Post #523833 5th Aug 2019 3:14pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Hi
Any update on this?
Both my upper and lower will soft close manually, but pressing the remote or tailgate buttons and it's a slam!!
It doesn't look like i have any alignment issues.
Thanks
Post #615345 8th Dec 2021 5:19pm
Jase71
Mine all works properly now. It was all about the alignment which required the hinges to be moved about until the doors closed with the soft close. Had to go to the body shop as the garage couldn't do it. 2017 Range Rover Vogue V6 Diesel
Post #615347 8th Dec 2021 5:21pm
PaulB
Thanks Jase
Post #615351 8th Dec 2021 5:37pm
