Home > Maintenance & Mods (L322) > 2010 - > deployable steps fitting. |
scooby1975 Member Since: 06 Aug 2016 Location: Hampshire Posts: 4 |
Cheers man, I’ll check it out. 👍 |
2nd Dec 2017 4:09pm |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
Just fitted mine to a 11.5 model year. NMJ's write up was invaluable thanks!
10th Feb 2018 6:38pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 |
Hi Macca,
6th Mar 2018 1:06pm |
Fatfred Member Since: 15 Dec 2017 Location: essex Posts: 55 |
i tried for 2 hours searching for the mystery connectors, in the end i gave up, the steps work perfectly without it FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 |
7th Mar 2018 7:43am |
Thanks for that. Perhaps I'll stop worrying about it too much then - I'm just trying to get my confidence level up before I start the job - I'm a bit nervous about getting stuck with the car in pieces (and the steps haven't even arrived yet!).
7th Mar 2018 9:11am |
mirras Member Since: 25 Mar 2018 Location: Prestwick Posts: 14 |
Received and fitted the kit yesterday and this write-up made things so much easier, thank you. Tapping out the M8 holes was a must, couldn't get the bolts started without it.
8th Apr 2018 6:31am |
There wasn't enough room to get the ratchet spanner over the end of the two offside rear bolts so it was open ended all the way... boring but doable |
8th Apr 2018 9:56am |
I've still got to find a slot to start doing mine! 2010 4.4 TDV8 Vogue SE |
8th Apr 2018 10:21am |
Been back out this morning and switch still not doing anything at all. Took it apart and tested it with a continuity tester and it's working fine. Must be the wiring or something else not quite right. I couldn't work out how to do the "set ignition to II and hold for 5 seconds bit" as it has a button start so I just pressed the start button without pressing the brake and held the step button in for a while. The steps operate as they should with the key and with doors opening and closing so I'm not too fussed about the button. |
8th Apr 2018 10:27am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
oh really, I got the ratchet ring over those. that air tank is tight close huh?
8th Apr 2018 10:43am |
Something I noticed in a thread on the IID tool is that there is apparently an option in the ccf for deployable side steps...?
8th Apr 2018 11:06am |
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 |
Kooky
8th Apr 2018 4:46pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1194 |
Hi, Mirras
8th Apr 2018 6:08pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
I turn on ignition , open door , then press and hold step button and steps then stay out enabling them to be washed. 2015 4.4 AB
8th Apr 2018 7:24pm |
