Home > Maintenance & Mods (L322) > 4.4 tdV8 turbo oil drain mod.
Page 14 of 15 <123 ... 131415>
landy95
DrRob wrote:
Chap on Facebook has an alternative easy first try fix for smoke screens. Put a new pump on. Easy to access on top of engine.
I’ll try and link to his post and video on Facebook. In essence, the pump wears and can’t suck the oil quick enough out of the turbo drain sump so it then backs up.
It worked for him so definitely worth a try for others. 👍😎
Mine smoked like james bonds aston when booted, it would last for about 20 seconds it was quite embarassing cars would disapear when I looked out the mirror. I don't have the oil drain mod but was thinking of doing it. I spotted DrRobs post and found a genuine brand new vacuum pump on ebay for £200, I thought it was worth a punt before going £1000 on the drain mod. I fitted the vacuum pump 2 weeks ago and I can happily say I have no more smoke. I plan to strip the old one down to see if I can work out why it failed. My thanks to DrRob for pointing out the Facebook suggestion. Also own a 1976 Land Rover 101 3.5 V8.
Previously owned 1991 Range Rover Vogue 3.9 V8.
Post #672651 3rd Sep 2023 9:21pm
GGDR
Amazing well done. Got a link?
. Cheers, Greg
Post #672653 3rd Sep 2023 9:43pm
GraemeS
Australia
I note that there's a later part number LR083155 for the pump that suits all 4.4s but that the original part number LR022758 isn't superseding to the later number when the original number is searched for. Microcat 2012 shows the MY13 L405 as having the original part number.
Post #672658 4th Sep 2023 2:23am
landy95
It looks like I had the last one it was the later part number LR083155 that I purchased. The company was Parks Motor Group.
Post #672662 4th Sep 2023 5:56am
DrRob
Great feedback and definitely worth trying a new pump as a first fix attempt for smoke screen cars Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #672663 4th Sep 2023 6:20am
Shaunj69
England 2012 Range Rover Autobiography 4.4 V8 Zambezi Silver
Nice report Landy95. I am going to go down that line. Many t
 L322 TDV8 2011 Autobiography
Working for an OE aftermarket car parts suppler
Post #672665 4th Sep 2023 7:33am
DrRob
Shaun - did this cure yours? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #673589 17th Sep 2023 1:04pm
InlovewithRR
United Kingdom 2012 Range Rover HSE 4.4 V8 Bonatti Grey
Hi Guys,
I have same smoke issue with my tdv8, replaced the pump, but it didnt cure the problem. I doubt about turbo drain mod as it was working fine then new. Anything to check ? I also run 5w50 oil instead of 5w30 maybe what could be an issue, but somehow hard to believe
Post #676028 21st Oct 2023 8:54am
kevinp
Whip your oil filter out and see if the valve is on it's post correctly and not loose in the bottom.
Post #676037 21st Oct 2023 10:17am
JayGee
I'm checking mine at next oil change. May also account for the oil light on cold start when parked on a slope. 2012 TDV8 Vogue (L322)
Post #676040 21st Oct 2023 10:50am
Baltic Blue
I didn’t know it served a valve function, I’ve always just thought it was a tensioner spring for the oil filter element, so will also be paying more attention to it every oil change.
Post #676043 21st Oct 2023 11:53am
JayGee
How many people actually look down there let alone knew this existed as you have to climb on the engine or use a mirror. 2012 TDV8 Vogue (L322)
Post #676044 21st Oct 2023 12:24pm
Baltic Blue
I always clean it out, but have never removed the “spring”
Mike
Post #676045 21st Oct 2023 1:10pm
DrRob
I do Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #676050 21st Oct 2023 3:01pm
kevinp
I do as well, because it's surprising how much more dirty oil you can get out with a syringe and a tube. That's how I spotted my 'spring valve' was loose.
Post #676054 21st Oct 2023 3:52pm
