Home > Off Topic > Slow computer fix? |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 828 |
I use Microsofts free AV and it serves me well. They update it regularly and it doesn't diminish computer performance, give it a go just because it's free doesn't mean it's rubbish.
27th Oct 2016 11:48am |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1247 |
I have been using Microsoft Essentials for around a year now and had no problems with it. We did have some AV program installed by a local computer shop, but the price started to go up and it started to get more pop-ups to buy additional stuff, so I binned it and installed Microsoft Essentials, seems to be working fine.
27th Oct 2016 1:20pm |
Worth noting that Microsoft got their AV technology from the acquisition of Antigen which was extremely well respected in the IT industry. |
27th Oct 2016 2:36pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
it doesn't like my computer I tried to download it.. gave up after an hour... it's been cancelling for nearly 2 And it still hasn't finished
27th Oct 2016 2:49pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1653 |
ahem... do I have to mention the M word again? 405 AB exec seats Baltic and Cirrus
27th Oct 2016 4:36pm |
Yeah, buy a Mac and all your troubles will cost 5 times as much |
27th Oct 2016 4:51pm |
The cheapest and arguably one of the best and easiest upgrades you can carry out on an oldish PC is to double or possibly quadruple the RAM.
27th Oct 2016 5:29pm |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
If you have installed an AV, make sure MS Defender is turned of - otherwise they will compete/bottleneck resources.
27th Oct 2016 6:33pm |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 |
Whilst I agree that more RAM, install SSD, Windows update etc is all good, the OP needs to provide more info on the PC he is talking about if he wants help. Is it a Laptop or a Desktop, what processor does it have, RAM size, Hard Drive type (IDE, SATA)? You need to get to the root cause of the problem before throwing money at the solution. It could be some 'bloatware' is sapping resources or the AV scanning is slowing things down as mentioned in a previous post. Installing an SSD or extra RAM will not solve your problems if you have (unknown) application processes sapping your compute power. Run Task manager as previously advised and by all means send me a PM if you need some help.
27th Oct 2016 7:16pm |
More ram I just keep on throwing more coal at it
27th Oct 2016 10:40pm |
If it's a 32bit processor then adding more RAM won't help. The 32bit CPU will only run 32bit Windows and thus it can only address (just under) 4GB of memory
28th Oct 2016 7:21am |
Ah, good old Vista This was released too early in 2007 to replace the ageing XP and is resource intensive due to it's fudged GUI. Vista went out of mainstream support in April 2012 and will be out of extended support in April 2017. That and your Trend AV and only 4gb of RAM is probably causing the latency. As per previous posts, suggest you replace Trend with MS Essentials, put in another 4gb if possible and upgrade to Windows 7 that is a lot less resource intensive. But do a 'ctrl/alt/del' first and fire up Task Manager to see what is eating your CPU and memory! SDV8 AB MY 2019
28th Oct 2016 7:33am |
Adding more than 4GB of RAM to a 32 bit system is a complete waste of money. It can't use it.
28th Oct 2016 8:15am |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 |
Is it true that they know what they're going to say, but can't stop themselves 2017 5.0 Autobiography Supercharged 2005 Merc SL350 2005 Disco HSE 2.7 oil burner |
28th Oct 2016 8:29am |
