Home > Technical (L322) > Lower thermostat modification V8 4.4 M62 2002-2005
Page 11 of 12 <123 ... 101112>
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
For a complete answer you need an LPG guy but engine temp still hits the 200 F mark so I see no reason why not.
Post #479111 22nd May 2018 5:09am
p38arover
Australia
Jmckenzie295 wrote:
My question is, I have lpg running, will this affect the automatic switch over from petrol to LPG?
I can't see why it should. The cars will run quite happily without the thermostat heating element. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #479115 22nd May 2018 7:05am
Deltaevo
United Kingdom 2002 Range Rover HSE 4.4 V8 Alveston Red
Jmckenzie295 wrote:
I am definitely thinking of getting this done. Probably will go with the BEHR as as far as I can see is a straight swap, correct?
My question is, I have lpg running, will this affect the automatic switch over from petrol to LPG? to clarify, the lpg won't run when the engine is cold and generally switches to it when the temp gets to the top of the blue.
Should this just work as is, or would something have to be changed?
Cheers
Running LPG on mine also, LPG now switches over much faster and earlier, mine is switching over at just over the first quarter mark.
Post #479120 22nd May 2018 9:41am
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
The LPG switchover will depend on a number of defaults (time, revs falling, pressure etc) and two defaults relating to the temperature will be the temperature switch over value (obviously) but also the time to switch to LPG from 1. Cold and 2. Warm / hot
Most LPG systems calibrate from 60 degrees C so this mod should be fine.
Personally my LPG is set to switch over within 5 seconds of starting and that’s about 18 degrees so I use very little petrol.
Hope this helps?
Regards,
John
Post #479143 22nd May 2018 4:42pm
Jmckenzie295
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Thanks guys, very helpful.
I think I will just tackle the modded version. Mainly because it allows me to put the connector on it.
Cheers
John
Post #479164 22nd May 2018 10:02pm
Jmckenzie295
So I done the modded thermostat today, all fits together nicely with the housing etc. However, only 3 bolts go in, the 3Rd will not seems to be the bottom two are slightly out.
Has anyone had this issue? What would you do to fix it? My main issue is the 3 parts to the modded thermostat came ready assembled and not sure if they can be pulled apart without damaging the paper gaskets in the middle.
Any thought welcome.
Cheers
Post #485664 10th Aug 2018 9:51pm
holidaychicken
You shouldn’t need to separate the parts and if the bolts go through with it out then you should be fine when fitted. Did you try rotating it 90 degrees in the housing and did you grind off the old mounts ok ?
Post #485667 10th Aug 2018 11:21pm
Jmckenzie295
Everything is grinded and smooth, the holes don't line up at all if at any other variant. Only one way. I would agree, but if when all bolts are in and the last hole ends up at a slight angle it won't go into the engine side of the thermostat. Well that's the only explanation I can come up with.
Post #485677 11th Aug 2018 7:55am
holidaychicken
I know one of the bolts is difficult to access which is why they supply cap heads but I used all all hex head as I used a 1/4 drive ratchet. Did you use the cap heads supplied and can you get all four bolts in lose to start them and then tighten ?
Post #485682 11th Aug 2018 8:36am
Jmckenzie295
The last one finally caught the thread. Alot of shifting about. But got their in the end.
Just testing now.
Hopefully positive outcome and on to the next job.
Cheers
John
Post #485692 11th Aug 2018 10:31am
holidaychicken
Post #485717 11th Aug 2018 4:06pm
nosmo
Is this mod still available?
Post #505939 21st Feb 2019 8:10pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Certainly is, here’s the link
https://rover.ebay.com/rover/0/0/0?mpre=ht...4183152212
Works a treat too Thumbs Up ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #505942 21st Feb 2019 8:28pm
nosmo
Thank you Thumbs Up
Post #505949 21st Feb 2019 9:01pm
p38arover
Australia
Frankly, having done the mod, I wouldn't bother. I'd buy the bolt-on non-heated thermostat housing that has a lower temp thermostat.
I think the part no. is Mahle or Behr TI 32 88 - it's an 88 deg C thermostat. See pix on page 3 of this thread.
One advantage is that you have a brand new part with no corrosion. I had to remove the old connector as it was leaking and then reseal and refit it. I then added lots of epoxy into the hole where the connector was originally. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #505983 22nd Feb 2019 3:45am
