Home > Maintenance & Mods (L322) > Red oil coming out of zf 5hp24 gearbox
Page 2 of 5 <12345>
It's how they classify oil..... yes it is equivalent oil, and is compatible with the correct oil BUT it doesn't have the necessary additives to protect the 5HP24....
Doesn't matter what it says on the can... if it's not Mobil LT71141 then it IS damaging your gearbox or at the least reducing it's life....
LT71141 oil is straw coloured, they don't make it in any other colour... Pete
Post #397929 27th Jul 2016 2:30pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
What he said! ^^^
Red/other colour = bad
Straw = good
The official Mobil oil has special additives that no other oil has
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner
Post #397940 27th Jul 2016 4:18pm
smiler289
This is what I have used. Put another litre in today. That's 6 litres in and got a little over 5 litres out when I changed the oil. So the mixture of straw colour to cherry colour oil should be around or just above 50/50 now.
Post #397945 27th Jul 2016 4:42pm
smiler289
That is what came out.
Post #397946 27th Jul 2016 4:43pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
mattstevenson2005 wrote:
What he said! ^^^
Straw = good
Matt
Anyone have the spec and data sheet on Mobil LT 71141? Like to see how it different from other label LT 71141 products.
Post #397966 27th Jul 2016 7:27pm
There is only one Mobil LT71141, that stuff you linked to says it's compatible with it and it is, it won't harm it at all... it doesn't replace it though... don't think Mobil will tell you what additives the oil has, it was made for ZF specifically for the 5HP24 when they decided to have the (IMHO potty) slipping TC to smooth the gearchanges....
It's the way they classify oil that is the problem, they can claim it is an equivalent/compatible but the classifications don't take the additives into account... Thumbs Up Pete
Post #397969 27th Jul 2016 8:02pm
doclees
No disrespect meant here but if we don't know what is in it you/we can't know if another company has licensed or copied the identical formula. I emailed liqui-moly regarding their product. They have 2 categories for this equivalent. The fact that the ZF 5hp24 is not listed under the approvals section concerns me.
Specifications and Approvals:
Allison C4 ; Caterpillar TO-2 ; Dexron III H ; Ford Mercon V ; Honda ATF Z1 (ausser CVT) ; Hyundai SP II ; Hyundai SP III ; JASO 1-A ; Kia SP-II ; Kia SP III ; Mazda ATF M III ; Mazda ATF M-V ; Mitsubishi SP-II ; Mitsubishi SP-III ; Nissan AT-Matic D Fluid ; Nissan AT-Matic J Fluid ; Nissan AT-Matic K Fluid ; Toyota Type T-II ; Toyota Type T-IV
LIQUI MOLY also recommends this product for vehicles or assemblies for which the following specifications or original part numbers are required:
Allison TES 295 ; BMW 7045 E ; BMW 8072 B ; BMW LA 2634 ; BMW LT 71141 ; Chrysler ATF +3 ; Chrysler ATF +4 ; Daimler NAG-1 ; JWS 3309 (Aisin Warner) ; MAN 339 Typ V1 ; MAN 339 Typ Z1 ; MAN 339 Typ Z2 ; MB 236.2 ; MB 236.3 ; MB 236.5 ; MB 236.6 ; MB 236.7 ; MB 236.9 ; MB 236.10 ; MB 236.11 ; Subaru ATF ; Voith H55.6335.XX (G 607) ; Volvo 97340 ; Volvo 97341 ; VW G 052 162 ; VW G 052 990 ; VW G 055 025 ; ZF TE-ML 02F ; ZF TE-ML 03D ; ZF TE-ML 04D ; ZF TE-ML 05L ; ZF TE-ML 09 ; ZF TE-ML 11A ; ZF TE-ML 11B ; ZF TE-ML 14A ; ZF TE-ML 14B ; ZF TE-ML 17C
Post #397982 27th Jul 2016 10:29pm
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
I did look into this prior to making a decision some years ago.
These are the type approvals for ZF transmissions;
Keeping in mind this is only for the 1200 fluid which is for the 5HP.
Liquimoly manufacture 6 synthetic transmission fluids last time I looked, the standard BMW LT 71141 I believe is all we need be concerned with here. Granted the standard would be a bench mark ie a low bar for certification meeting this standard. Liquimoly is a German company and this product is actually made in Germany.
The feed stock for this fluid would most likely only come from one manufacturer other resellers can ad what they like to it even COLOUR it.
You can actually get this product in a Yellow fluid.........it has the same specs.
I am paying just under $AUD 20 for a litre
The first time I drained my trans and dropped the pan off the fluid was very dark (filthy) As I say 3 years later all is well, I will be doing another change soon which should see the fluid improve some more.
Looking forward to Liquimoly response.
Post #397986 28th Jul 2016 1:11am
RR P38
Its all cool Doclees, a good debate is, well good.
Your concern that our trans is not on the list is nullified.
All the ZF approvals are at the end of the list;
The one that concerns us is;
ZF TE-ML 11A
www.zf.com/global/media/en_zf/lubricantslists/TE-ML_11.pdf
Post #397987 28th Jul 2016 1:24am
doclees
I found this for more clarity and confusion.
http://www.meurosport.com/ZF_Transmission_Fluid.php
Looking at the TE ML 11 Mobil is not listed at all for the 5HP24 . I would think if Mobil brand of LT 71141 was the original and best product ZF would have listed it by name.
The link above talks about fluid longevity. I've been using Febi brand and at $10 US a liter I'll happily change out 4 liters every 15k miles just in case.
Post #397990 28th Jul 2016 3:44am
RR P38
Yes I see what you mean re the Mobil product, it doesnt have the 11A (which the Top Tech 1200 Liquimoly) rating, which gives it the thermal stability from what I read of it.
Obviously with our engines normal running range in excess of 105c thermal stability is what you are looking for.
I have never been a fan of Mobil products anyways as an example I consider Mobil 1 to be a well over priced engine oil with poor performance for a synthetic oil.
This is all secret Land Rover business, they dont like people working on their own vehicles.
Keeping the punters confused is their trade and profit.
Doclees, I do the same as you with regard to fluid changes on the trans, I am running a P38 with nearly 400,000km on it and have been applying this practice to it for the last 16 years, original trans, its still shifts like new.
To be honest I dont think you need to flush the trans just drop the fluid and take a look at whats really going on every 12 months or so.
I have always had Landrovers for my outback expeditioning over 30 years now and I operate in some pretty remote areas, being able to repair or patch up a failing vehicle is a major advantage the L322 tests this to the limit, yes they are reliable if well understood and maintained but I think they are the last FF that will be use full in outback situations a P38 is far more serviceable and better still a manual TDI Disco.
Post #398009 28th Jul 2016 10:00am
I appreciate what you are saying, and if it works for you and your happy with it then great....
Just can't see the point of using an oil that "maybe" ok when it's not hard to get the correct oil that you "know" is ok, it's not even a massive saving when you compare it with the cost of a new transmission....
It's a bit like the argument about OE and non OE parts, for example, you can get an original rear hub bush for about �30 or you can get a Britpart special for about �3, they are both made of metal and rubber, they both look the same the manufacturers say they will both fit and do the job.... from experience I "know" that the cheap ones will last less than a year if you use your FF off road at all, the genuine ones last for years and years.... So, is it really worth saving �27 when changing them??
The point I was trying to get across with the oil is that no one really knows if there is another oil that is exactly the same, manufacturers will claim anything to sell their products, because, let's face it, who can dispute it, we don't have the facilities or the knowledge to argue that what they are saying is true or not.....
Just after I left school I worked in a petrol station, they were selling 2,3,4 and 5 star leaded petrol at that time but when the tanker pulled up I noticed that he filled all the tanks with the same petrol, when I asked why I was told that the specifications of the different octane ratings had such a large variation built in that they just used 4 star for all of them and no one could prove that the petrol wasn't what it was sold as..... Pete
Post #398010 28th Jul 2016 10:06am
doclees
This is the response I got from liqui-moly.
Dear Mr Corey,
Thank you for your inquiry from the 07.27.2016 and the interest in our products.
The difference between ''Specifications and Approvals'' and ''Recommendations'' is, that the Specifications and Approvals are tested by the OEM and the Recommendations we as the manufacturer guarantee for the usability. In some cases like for the approval LT 71141 it is not possible to get the approval from the OEM, so we have to write it under ''Recommendations''.
All our products are tested and are safe to use. The Top Tec ATF 1200 is absolutly suitable for ZF 5HP gearboxes.
We hope we could help you with our informations. Should you have further questions regarding our products we would be very pleased to get contacted from you again.
Freundliche Gr��e / Best regards
i. A. Andreas Zahner
Post #398039 28th Jul 2016 1:13pm
Ask him to guarantee that it has exactly the same additives as LT71141, be interesting to read his reply.... as I said, they will say anything because you can't prove otherwise.... it is not any ones job to ensure that their claims are true....
If your box fails because of their oil you have no way of proving it.... Pete
Post #398043 28th Jul 2016 1:37pm
doclees
So as i do more research it gets more convoluted. I go to Exxon/mobil to find info. They do not list 71141. Not a US product. Seems to me if ZF only wanted Mobil brand 71141 in there transmissions that is what you would find in the dealerships. Then again they said it was a sealed for life transmission.
Further sources list Fuchs of Germany as the manufacturer of esso and Mobil brand 71141. I'm still trying to find out who makes it for Febi and if it is licensed or if a license is even still needed.
One should keep in mind that 71141 is a 20+ year old semi synthetic product. I can't imagine there hasn't been an improved version by now.
Elsewhere one source said the red color in the fluid is nothing more than color dye.
Post #398080 28th Jul 2016 4:56pm
Page 2 of 5 <12345>
