Home > Technical (L322) > SC Brake Upgrade
dhallworth
SC Brake Upgrade
I'm about to order discs and pads for the front of my 2006 SC.
I was wondering, just out of interest, are the 6 piston Brembo calipers from the newer cars a straight swap for the 4 piston ones fitted to my car? I'm just wondering if the hubs and mounting points for the callipers are the same.
The 6 piston brakes on the 4.4 TDV8 we've got are better then the ones on the 4.2 SC so am wondering if it's worth the hassle of changing them.
Post #396513 17th Jul 2016 8:08pm
Looking at microcat it is a different part number for the hub carrier, and they do attach differently. The 4 pots are the threaded part of the attachment so the bolts go through the hub carrier and into the caliper, on the 6 pots the carrier is threaded and the bolts go through the caliper and thread into the hub. I presume that this was because folks kept stripping the threads in the 4 pot calipers. When changing discs. There is nothing that can't be fixed with a hammer😜😜
Post #396515 17th Jul 2016 8:37pm
dhallworth
Ahh, that ends that idea then.
I can't be bothered with the hassle of changing the hubs as well!
New Brembo discs and pads it is then Smile
Post #396518 17th Jul 2016 8:44pm
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
The man to ask is Discomikey, he has fitted them to his D3 as have a few others on that forum Thumbs Up
http://www.disco3.co.uk/forum/topic139030....bo+upgrade
Paul Thumbs Up Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #396523 17th Jul 2016 9:06pm
dhallworth
Thanks Marsie, I'll ping him a message later Thumbs Up
Post #398267 29th Jul 2016 3:21pm
on the D3 and D4 the bit the carrier bolts too is the same config as the 6 pots with the thread in the hub section not the caliper itself.
It might be doable, but I'm not sure that it is straightforwards. Also remember that they are bigger callipers so may require different wheels. Just something to bear in mind. Does rather depend on what you have fitted at the moment though.
Thumbs Up Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #398279 29th Jul 2016 4:15pm
marsie
Seem to remember the guys over on D3 said 19" minimum to clear 4 pots but 20" needed to clear 6 pots-But thats on D3/rrs so may be different on FFRR but i suppose if its a 4.2sc it will probably have 20s anyway Thumbs Up Paul
Post #398340 29th Jul 2016 11:31pm
dhallworth
I've decided to give this a bit more thought...
So far, I've worked out that I need:
LR016659 - RH 6 pot caliper
LR016661 - LH 6 pot caliper
LR010677 - RH Front Knuckle
LR010678 - LH Front Knuckle
LR031845 x 2 - Front Brake Discs
LR083935 - Front Brake Pads
I'm using man maths at the moment... My front brakes need the discs and pads doing and upgrading them now makes sense Laughing
One thing I am wondering about after speaking with a friend last night... Will the master cylinder need changing due to the bigger calipers needing more pressure/fluid to work them?
Post #424395 23rd Jan 2017 11:03am
Mikey
No, as long as the MC is OK, it'll be fine Thumbs Up
Post #424452 23rd Jan 2017 8:06pm
dhallworth
Thanks Mikey. Thumbs Up
I've compiled a list of everything I think I'll need...
Hubs & new wheel bearings
Calipers
Flexi hoses
Discs
Pads
Whilst I'm in there I'm going to renew both front wheel bearings when changing the hubs and give anything that needs changing a new lease of life. Seeing as it passed it's MOT without any advisories I'm hoping there won't be very much.
If anybody wants a set of 4 piston Brembo's with new genuine LR flexi hoses on them, get in touch Laughing
Post #424485 23rd Jan 2017 10:14pm
Sandyt
Interested to hear how you get on with this sounds like a good upgrade
Post #424629 24th Jan 2017 8:21pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
To be honest, it does seem pointless. The 4 piston brakes are more than enough for these.
Good luck though Thumbs Up Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #424896 26th Jan 2017 5:00pm
dhallworth
When you drive our 4.4 TDV8 with the 6 piston brembo calipers on it and then drive the 4.2 SC with the 4 piston brembo's on it there is a noticeable difference. The newer brakes feel more sure footed and don't fade like the earlier ones do if working them hard.
I do agree though, for the amount of time I use the car and the way I drive it, I won't notice much difference at all in day to day driving so it is a bit pointless. However, the bigger brakes do look *much* bigger and better behind the wheels. They fill the wheel much more. When looking at them side by side the discs on the 4.2 SC actually look small. Laughing
Hey ho, it'll give me something to do and keep me out from under the wifes feet for a while... Well, until she sees the bill for calipers along with genuine discs and pads for both the front and rear, then I'll be well and truly in the dog house. Laughing
Anyway, more updates to follow when I pluck up the courage to start buying things! Thumbs Up
Post #424923 26th Jan 2017 7:20pm
Mikey
Biiiiiig difference Thumbs Up
Post #424935 26th Jan 2017 8:38pm
zarnd
Be interesting to see how you get on and what you think. Expensive, but fun and something to do Thumbs Up Alex
2007 M5 Touring
2004 SL55 AMG
Post #425036 27th Jan 2017 1:06pm
