![]() | Home > Technical (L322) > SC Brake Upgrade |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8702 ![]() ![]() ![]() |
Looking at microcat it is a different part number for the hub carrier, and they do attach differently. The 4 pots are the threaded part of the attachment so the bolts go through the hub carrier and into the caliper, on the 6 pots the carrier is threaded and the bolts go through the caliper and thread into the hub. I presume that this was because folks kept stripping the threads in the 4 pot calipers. When changing discs. There is nothing that can't be fixed with a hammer😜😜
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3156 ![]() ![]() ![]() |
Ahh, that ends that idea then.
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 ![]() ![]() ![]() |
The man to ask is Discomikey, he has fitted them to his D3 as have a few others on that forum |
Thanks Marsie, I'll ping him a message later |
on the D3 and D4 the bit the carrier bolts too is the same config as the 6 pots with the thread in the hub section not the caliper itself.
Seem to remember the guys over on D3 said 19" minimum to clear 4 pots but 20" needed to clear 6 pots-But thats on D3/rrs so may be different on FFRR but i suppose if its a 4.2sc it will probably have 20s anyway |
I've decided to give this a bit more thought...
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1792 ![]() ![]() |
No, as long as the MC is OK, it'll be fine |
Thanks Mikey. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2275 ![]() ![]() ![]() |
Interested to hear how you get on with this sounds like a good upgrade |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
To be honest, it does seem pointless. The 4 piston brakes are more than enough for these.
When you drive our 4.4 TDV8 with the 6 piston brembo calipers on it and then drive the 4.2 SC with the 4 piston brembo's on it there is a noticeable difference. The newer brakes feel more sure footed and don't fade like the earlier ones do if working them hard.
Biiiiiig difference |
Be interesting to see how you get on and what you think. Expensive, but fun and something to do |
