Home > General > My cars at the dealers today.
Page 1 of 3 123>
JustinP
My FFRR is in for some warranty work today, this is the first time I’ve handed it over to the dealers since I bought it in September.  As I live in Cambridge, its gone into Marshals who don’t have the best reputation, so I’m praying they don’t damage anything.
I’ve asked them to look at the following
1.    Access height door switch does not work.
2.    Front wipers clank when the change direction, I'm sure its just the angle that needs adjusting, but as its going in under warranty they might as well do this.
3.    Read screen wash does not work, although you can hear the pump running.
4.    Has stalled a couple of times immediately after starting when its below 4 degrees C outside.
5.    Bonnet needs a couple of attempts to latch properly when its closed, I almost messed my seat when it popped up a couple if inches when joined the dual carriageway at the weekend
I’ve also asked them to check the battery.
So nothing to serious, but enough little bits to justify a trip to the dealers.
Cheers
Justin
Post #38783 24th Nov 2010 10:08am
i see yours is a 2006 model so is that rover warranty or after a market one.. ... - .- -.
Post #38789 24th Nov 2010 10:18am
JustinP
It's a Rover one as I bought the car from a LR dealership.
Post #38790 24th Nov 2010 10:20am
thats handy to know.. Thumbs Up ... - .- -.
Post #38792 24th Nov 2010 10:22am
iT LAD
Yep, handy to have the warranty... Thumbs Up Thumbs Up
Did they give you a loan car?
Post #38832 24th Nov 2010 11:08am
Fox
I thought the extended warentee was an aftermarket one, sold by the main dealer.
When I took out mine on the 06 I got a pack through the post. It wasn't from Land Rover. Sad
And you had to pay the diagnostic charge yourself if it was needed to stop you putting it in the garage every 5 minutes.
Post #38839 24th Nov 2010 11:14am
JustinP
Approved used LR's come with a 12 month LR warrenty.
Not that its worth the paper its written on. The stalling on cold start up has been put down to needing a software update, and software updates are not covered by the warranty. Neither is the blocked screen wash, or the clanking wipers Evil or Very Mad
Cheers
JustinP
Post #38947 24th Nov 2010 12:59pm
JustinP wrote:
.....and software updates are not covered by the warranty. Neither is the blocked screen wash, or the clanking wipers Evil or Very Mad
Cheers
JustinP
Sounds about right then Big Cry
Post #38950 24th Nov 2010 1:02pm
JustinP
Picked the car up this evening, and the wipers were silent whilst driving home in the rain - bliss Smile
Post #39106 24th Nov 2010 6:49pm
a bit of good news then justin.. Thumbs Up ... - .- -.
Post #39129 24th Nov 2010 8:02pm
So did they charge you for the incidentals?
Post #39138 24th Nov 2010 8:14pm
JustinP
They charged me for everything other than the door access height button, but I'm pleased with the silent wipers and the higher revs on cold startup, I still need to check the rear screen washer is working.
Total cost £108
I still cant believe that a genuine LR used car warranty does not cover software updates, when a stalling car has been attributed to what is effectively a software bug. If I can be arsed I will write a letter voicing my disgust.
Cheers
JustinP
Post #39209 24th Nov 2010 11:04pm
DMRR
Approved is NOT a genuine LR warranty. It's very very different! Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #39211 24th Nov 2010 11:25pm
JustinP
My FFRR stalled again today on cold startup, so the ECU software update has not fixed the problem.
Time for a new battery!
Cheers
JustinP
Post #40101 29th Nov 2010 7:51pm
Cheers
JustinP
If it turns Ok and starts fine but then stalls its unlikely to be the battery Confused
I have same problem but the battery is perfect. I think it needs to be a bit richer at startup (choke effect missing)
Last edited by Gazellio @ Prestige Cars on 29th Nov 2010 8:00pm. Edited 1 time in total
Post #40106 29th Nov 2010 8:00pm
Page 1 of 3 123>
