Home > Maintenance & Mods (L322) > Drivers Door Handle
Page 3 of 5 <12345>
VaguelyVogue wrote:
-5C this morning and the drivers door wouldn't stay shut (once I had got in), so I locked it with the button ... Then 20 minutes later, after unlocking with the central locking, neither inside nor outside door handle would open the door - is it likely that both cables have gone ?
mine was like this today, i thought i'd cured it by spraying silicon lubricant in the locks but apparently not...if you drive the RR it takes about 10/15 minutes to defrost..more spraying me thinks.. ... - .- -.
Post #39473 26th Nov 2010 8:29am
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Thanks - a frozen lock would be great - I can get the silicon spray out this evening (door seals need some too) - here's hoping !!
Post #39474 26th Nov 2010 8:36am
VaguelyVogue
Correct diagnosis - a frozen lock which had defrosted by this evening - big relief !!
Post #39618 26th Nov 2010 10:53pm
this frozen door handle in a pain..this morning i had to go to the hospital at 4.30am and the bloody handle was frozen so i had get in through the passenger side..not a good impression for a RR.. ... - .- -.
Post #39668 27th Nov 2010 8:27am
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
yep this was what i experienced. I suspect the manual locking was just enough to jolt it free but then it refreezes. I was sent down the cable path at rr.net or what ever its called. Maybe its just the latch needing some vaseline.. Handle is crotchy so i'll do the cable regardless.
Either that or you parked to close to a bollard or bin. Laughing 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #39706 27th Nov 2010 12:45pm
found and solved the freezing problem...its the mechanism at the back of the door latch which gets frozen..water runs down the inside right onto this mechanism and causes the problem...you need to dry the area with a hairdryer and cover it with silicon lubricant and for extra protection put some grease or similar on it....the proof in the pudding will be tomorrow morning when i test the door... ... - .- -.
Post #39853 28th Nov 2010 2:20pm
Cheers scarey that happened to me at 1.30am this morning going to pick the daughter up opened door , door would not lock once inside had to drive 3 miles holding a door closed from the inside ......... Mad
Post #39855 28th Nov 2010 2:26pm
i was getting in and out via the passenger door and that wasnt easy for an old git like me...
i'm convinced its a design fault, there's a runner that comes right onto the gubbins and douses it with water... ... - .- -.
Post #39856 28th Nov 2010 2:28pm
Tell me about it done that last week .............
Hip replacement ordered Laughing
Post #39857 28th Nov 2010 2:30pm
its dead embarrassing seeings its a premium motor vehicle.. ... - .- -.
Post #39858 28th Nov 2010 2:31pm
My mate gave me this to try so time will tell tomorrow ....... sprayed this in the door lock just now
Post #39861 28th Nov 2010 2:41pm
Also meant to say that pfege stuff for the door seals work , Thumbs Up
Post #39863 28th Nov 2010 2:44pm
handy to know re the 'pledge' ...spraying in the door lock wont work mick [tried it Crying or Very sad ], the lubricant cant get to the back of the lock where the water accumulates ... the only way is by taking the door card off and getting in that way.. ... - .- -.
Post #39890 28th Nov 2010 5:00pm
The spray somehow worked scary, -7 this morning opened the door fearing it would not lock when i closed it , but the lock worked fine , do for me ........ Thumbs Up
Post #39977 29th Nov 2010 10:30am
dan_uk_1984
It will only freeze if there is water in there in the first place - and there shouldnt be.
Post #39982 29th Nov 2010 11:11am
Page 3 of 5 <12345>
