Home > Maintenance & Mods (L322) > 2007 3.6 TDV8 Thermostat housing Replacement |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 |
I was going to do a detailed post about the very same job that I have just done, but for some reason all but one photo is on my phone.
21st Feb 2016 9:21pm |
Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 123 |
That's great
21st Feb 2016 10:50pm |
Hi Steve, any others gaskets/parts you think I should order for this job other than the thermostat housing and elbows.
22nd Feb 2016 11:37pm |
There is a whole rake of gaskets that you could order, egr gaskets mainly, but I didn't bother.
23rd Feb 2016 12:00am |
28th Feb 2016 5:40am |
Looks like it is starting to let go on that welded seam.
28th Feb 2016 4:59pm |
Good Steve,
29th Feb 2016 11:43am |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
Paul,
29th Feb 2016 12:55pm |
Bloody good, check out this write up.
29th Feb 2016 1:26pm |
I did say in another thread that they would be good Regards
29th Feb 2016 1:29pm |
3rd Mar 2016 10:15pm |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
i had mine done last year as it was cracked by my mate took him a few days and did a few other bits while stripped _____________________________________________________
4th Mar 2016 1:38pm |
That looked to be leaking worse than ours seeing all that crud around the oil filter housing.
4th Mar 2016 9:05pm |
It's possible there was more than one leak, I dis had a slow leak for over year which I couldn't find as I'd say as it leaked the heat from the engine evaporated the water leaving the coolant deposits. When it got worse that may have been the original leak or maybe a second leak. With the second leak sometimes I could see coolant under the car.
5th Mar 2016 8:21am |
