Home > Technical (L322) > Td6 fuel injector |
espaceboy Member Since: 02 Aug 2014 Location: Fae Fife Posts: 86 |
I am guessing you have watched ed china diagnose the loom by using a test injector? |
24th Jan 2016 6:06pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8503 |
good call first on the TD6, if the injector wiring is faulty it can throw up a code even if the injector itself is OK. good place to start is to check the injector wiring loom, it is a lot easier to swap out than a duff injector too. There is nothing that can't be fixed with a hammer😜😜
24th Jan 2016 6:27pm |
Steveo Member Since: 26 Jan 2015 Location: Essex Posts: 156 |
How do I check the injector loom |
24th Jan 2016 6:32pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2640 |
I may have a spare injector lying about, will need a refurb but will mean you can stay mobile |
24th Jan 2016 6:47pm |
Steveo
24th Jan 2016 7:01pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Injectors are not coded so it's plug and play........... provided that you can get them out............. they can be a bit of a pain Yesterday I couldn't spell Engineer... Today I are one!
24th Jan 2016 10:36pm |
Previously for mine i got someone with a hydraulic puller, took him about 20mins to get them all out as he moved along the head and they were a bit stuck FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
25th Jan 2016 1:28pm |
clarkie Member Since: 26 Aug 2013 Location: leicester Posts: 51 |
try swapping the wiring conections over from injector 3 to 2 then check to see if the fault has moved injector. if theres enough freeplay in the wiring that is, if it moves its a wiring fault. |
25th Jan 2016 4:15pm |
