![]() | Home > Technical (L322) > Td6 fuel injector |
espaceboy Member Since: 02 Aug 2014 Location: Fae Fife Posts: 86 ![]() ![]() ![]() |
I am guessing you have watched ed china diagnose the loom by using a test injector? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
good call first on the TD6, if the injector wiring is faulty it can throw up a code even if the injector itself is OK. good place to start is to check the injector wiring loom, it is a lot easier to swap out than a duff injector too. There is nothing that can't be fixed with a hammer😜😜
Steveo Member Since: 26 Jan 2015 Location: Essex Posts: 156 ![]() ![]() ![]() |
How do I check the injector loom |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2665 ![]() ![]() |
I may have a spare injector lying about, will need a refurb but will mean you can stay mobile |
Steveo
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3660 ![]() ![]() |
Injectors are not coded so it's plug and play........... provided that you can get them out............. they can be a bit of a pain |
Previously for mine i got someone with a hydraulic puller, took him about 20mins to get them all out as he moved along the head and they were a bit stuck |
clarkie Member Since: 26 Aug 2013 Location: leicester Posts: 51 ![]() ![]() ![]() |
try swapping the wiring conections over from injector 3 to 2 then check to see if the fault has moved injector. if theres enough freeplay in the wiring that is, if it moves its a wiring fault. |
