Home > Technical (L322) > Td6 fuel injector
Steveo
Td6 fuel injector
Good evening all I have a problem with my number 3 injector on the iidt tool live values it is saying +6 and I have a missfire so am looking at replacing the injector I have put red X in ect but no joy can any body tell me if the injector needs coding or is it just fit and forget also if I fit a second hand one will this need coding cheers all
Post #368712 24th Jan 2016 5:32pm
espaceboy
I am guessing you have watched ed china diagnose the loom by using a test injector?
Post #368714 24th Jan 2016 6:06pm
good call first on the TD6, if the injector wiring is faulty it can throw up a code even if the injector itself is OK. good place to start is to check the injector wiring loom, it is a lot easier to swap out than a duff injector too. There is nothing that can't be fixed with a hammer😜😜
Post #368720 24th Jan 2016 6:27pm
Steveo
How do I check the injector loom
Post #368721 24th Jan 2016 6:32pm
Mr Tee
I may have a spare injector lying about, will need a refurb but will mean you can stay mobile Thumbs Up
Post #368726 24th Jan 2016 6:47pm
espaceboy
Steveo
looks like Ed continuity checked the wiring with a meter
Post #368729 24th Jan 2016 7:01pm
miggit
Injectors are not coded so it's plug and play........... provided that you can get them out............. they can be a bit of a pain Sad Yesterday I couldn't spell Engineer... Today I are one!
Post #368763 24th Jan 2016 10:36pm
Previously for mine i got someone with a hydraulic puller, took him about 20mins to get them all out as he moved along the head and they were a bit stuck Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #368828 25th Jan 2016 1:28pm
clarkie
England 2005 Range Rover Vogue Td6 Adriatic Blue
try swapping the wiring conections over from injector 3 to 2 then check to see if the fault has moved injector. if theres enough freeplay in the wiring that is, if it moves its a wiring fault.
Post #368851 25th Jan 2016 4:15pm
