Home > Technical (L322) > Welding exhaust in situ ...
chaybra
Australia 2006 Range Rover Vogue Td6 Zambezi Silver
I make it a rule to never weld on a car with complicated computers like the rangies. Only if its an absolute must, I will disconnect every computer I can get my hands on but by that time, you may as well remove whatever it is you are welding. Being an exhaust, its easy.
I have worked on larger earthmoving gear where despite the batteries being disconnected, welders have fried $60k worth of computers in a minute.
Post #350677 5th Oct 2015 5:43am
ebajema
I would prefer to not take the risk of welding current frying the electronics by using the double earthlead close to weld method for difficult to remove parts but on easy parts just take it off.
We had an issue with an automatic welding machine (offshore pipeline welding) that fried it's own control eletronics because a little weld spatter (the parameters weren't set perfectly yet and we used a CO2 root weld) landing on the torch and torch holder, bridging the insulating sleeve. The current went straight through our computer and before we realized it was the weld spat blob thingy we fried two PCBs worth about 250 USD each Sad.
We used a different sleeve / torch / arm pretty soon as well after that (and order plenty spare PCBs just to be sure).
As for welding wire and gas, if the stainless wire holds great, if not you can still get carbon steel wire.
Unfortunately I don't have access to gas/oxy welding equipment as well as my dads magic hands (as in he is still alive and kicking just living a 12 hour plane ride from here) in case I would have to do welding on an exhaust or structural member. He did magic for me on my old Triumph Herald that I bought as a poor student. Hole in the muffler, he would patch is up, no problem, big patches as well, amazing to see such skill. Save me tons of money (and him as well for his own cars).
Luckily I do have my hobby MIG and CO2 cylinder here so I can still finish my trike (well first finish this 3 month paying job Smile ).
Sorry got a bit off track Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #350678 5th Oct 2015 6:21am
acrr1
United Kingdom 2002 Range Rover Vogue Td6 Oslo Blue
Disconnect as Craig says, or use one of these or similar
http://www.ebay.co.uk/itm/Power-TEC91144-A...4640842209
Post #350680 5th Oct 2015 7:10am
miggit
Shocked OOOooooo I forgot about those clip on anti zap protection things, when they first appeared on the market they were such a stupid price it was cheaper to fry the ECU's Laughing But that is a good price, the only question is do they work? I'll have a dig around I thinks Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #350696 5th Oct 2015 9:09am
acrr1
yes they do - of course disconnecting the battery is cheaper!
Post #350702 5th Oct 2015 9:50am
Haylands wrote:
Never had any bother frying ECU's either, without fancy earth straps and never waited for longer than 5mins after disconnecting battery (didn't know you should Craig Embarassed Embarassed )... also have to admit to not bothering on several occasions and not had any bother... maybe I've just been lucky though...
Pete, its simply belt & braces pal... If you do a soft battery reset, you wait for the ECU’s to power down, loose their residual power, kept in capacitors etc etc... Not everyone would understand a hard battery reset! But would negate the need to wait Thumbs Up
Post #350705 5th Oct 2015 10:05am
miggit wrote:
The hours wait is lunch time Wink He didn't think to start earlier Laughing I would have thought that once the battery was disconnected everything was pretty much isolated, especially if you keep the weld area to a minimum ie, don't earth at the front bumper and start welding the rear Shocked
FYI Argon / 5% Co2 mix is the best thing for steel, not pure Argon, which is normally used with a TIG on stainless and ally. I did try an Argon / Co2 / Oxygen mix once, worked well with surface rust, but I'd recommend a good wire brush and get the cheaper stuff Thumbs Up
Miggit, as i said to Pete above, its a belt & braces thing pal...
And when you do an ECU scan and realise there are between 20 & 35 ECU’s in all FF's Whistle Could be a VERY costly mistake Shocked
Post #350708 5th Oct 2015 10:11am
miggit
Craig, bud, I understand the belt and braces bit, at the end of the day you is playing with someone elses' ffrr and as a business you have to look after the companies interests, wouldn't want to be explaining why an ECU has stopped working Embarassed Have you any experience of those de-couplers ?
And I suppose that it's wise to err on the side of caution, lets face it a ffrr doesn't need much of an excuse to bit you in the bum Shocked Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #350732 5th Oct 2015 1:17pm
Cheers Craig...
Miggit, it was 5% something else gas, not neat Argon
It's always the way though... I mean to disconnect the battery,
just keep forgetting, I've been lucky up to now... Pete
Post #350740 5th Oct 2015 1:32pm
miggit
Pete, for mild steel you should use 5% Co2 95% Argon for metal up to 5mm thick and it used to be 10% and 15 % Co2 for thicker, but I think that they now only have 1 (BOC) they call them Argoshield light (5%) and Heavy , In fact scrub that I've just had a peek and they now do light up to 4 mm, Universal 4 to 10 mm, and heavy 10mm +.
Most people that do welding gas, do a Argon Co2 mix, 5% to 7.5% Co2 is what you need for de tin stuf Cool
1-2% Oxygen in the mix is fine, but I wouldn't pay extra for it. In fact I'm not too sure if they still add Oxygen in to the mix, it was supposed to increase the weld temp and help with slightly oxidised material, I found that it was good on paint Very Happy Yesterday I couldn't spell Engineer... Today I are one!
Post #350744 5th Oct 2015 1:49pm
miggit
Pete there's no need to remove the battery connections when your welding your bumper on the bench Rolling with laughter
If you've been welding on the car Shocked Luck must be your middle name Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #350745 5th Oct 2015 1:53pm
miggit
Well I've just had an interesting 10 minutes going through Rave in the Body Repair section, and while it does say to disconnect the negative lead from the battery it does not recommend disconnecting any ECU's, but it does recommenced that the alternator is disconnected in most operations, and waiting 2 minutes before starting Thumbs Up
I've also been looking in to the Anti Zap thingy, to see if they do / don't work, from what I can make out they do work, and they seem to be a favorite with the exhaust fabricators, all be it the Snap On one, with the Snap On price tag Shocked
I'm now wondering if there is any mileage in disconnecting the battery and fitting one of those anti zappers, or do they require 12 v to work? Yesterday I couldn't spell Engineer... Today I are one!
Post #350755 5th Oct 2015 2:53pm
acrr1
I'm happy to be corrected by someone more qualified however my understanding is that they act as a surge protector so monitor the voltage for any spikes and cut to a safe level if necessary, so logically the battery would need to be connected.
Post #350780 5th Oct 2015 5:54pm
Miggit... Oh I see, I thought if I welded anything that has been anywhere near the fatty I best disconnect the battery.... Rolling with laughter Rolling with laughter
I actually welded these on with it connected.... oooops
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #350923 6th Oct 2015 5:43pm
miggit
Bow down Bow down You Live Close to the Edge, Pete Bow down Bow down
And welding precautions, not only should you disconnect the battery if you are welding with in 50 feet of the car, I recon that you should drain the tank and have a Fire Engine on standby Laughing One can never be too careful Shocked Land Rover was a part of British Leyland Shocked Shocked Enough said Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #350956 6th Oct 2015 9:54pm
