![]() | Home > Technical (L322) > Welding exhaust in situ ... |
I would prefer to not take the risk of welding current frying the electronics by using the double earthlead close to weld method for difficult to remove parts but on easy parts just take it off.
acrr1 Member Since: 30 Aug 2015 Location: Thirsk Posts: 24 ![]() ![]() ![]() |
Disconnect as Craig says, or use one of these or similar
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
yes they do - of course disconnecting the battery is cheaper! |
Pete, its simply belt & braces pal... If you do a soft battery reset, you wait for the ECU’s to power down, loose their residual power, kept in capacitors etc etc... Not everyone would understand a hard battery reset! But would negate the need to wait ![]() |
Miggit, as i said to Pete above, its a belt & braces thing pal... And when you do an ECU scan and realise there are between 20 & 35 ECU’s in all FF's ![]() ![]() |
Craig, bud, I understand the belt and braces bit, at the end of the day you is playing with someone elses' ffrr and as a business you have to look after the companies interests, wouldn't want to be explaining why an ECU has stopped working |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8374 ![]() ![]() ![]() |
Cheers Craig...
Pete, for mild steel you should use 5% Co2 95% Argon for metal up to 5mm thick and it used to be 10% and 15 % Co2 for thicker, but I think that they now only have 1 (BOC) they call them Argoshield light (5%) and Heavy , In fact scrub that I've just had a peek and they now do light up to 4 mm, Universal 4 to 10 mm, and heavy 10mm +.
Pete there's no need to remove the battery connections when your welding your bumper on the bench |
Well I've just had an interesting 10 minutes going through Rave in the Body Repair section, and while it does say to disconnect the negative lead from the battery it does not recommend disconnecting any ECU's, but it does recommenced that the alternator is disconnected in most operations, and waiting 2 minutes before starting |
I'm happy to be corrected by someone more qualified however my understanding is that they act as a surge protector so monitor the voltage for any spikes and cut to a safe level if necessary, so logically the battery would need to be connected. |
Miggit... Oh I see, I thought if I welded anything that has been anywhere near the fatty I best disconnect the battery.... |
