Home > Technical (L322) > Welding exhaust in situ ... |
I would prefer to not take the risk of welding current frying the electronics by using the double earthlead close to weld method for difficult to remove parts but on easy parts just take it off.
5th Oct 2015 6:21am |
acrr1 Member Since: 30 Aug 2015 Location: Thirsk Posts: 24 |
Disconnect as Craig says, or use one of these or similar
5th Oct 2015 7:10am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
OOOooooo I forgot about those clip on anti zap protection things, when they first appeared on the market they were such a stupid price it was cheaper to fry the ECU's But that is a good price, the only question is do they work? I'll have a dig around I thinks Yesterday I couldn't spell Engineer... Today I are one!
5th Oct 2015 9:09am |
yes they do - of course disconnecting the battery is cheaper! |
5th Oct 2015 9:50am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Pete, its simply belt & braces pal... If you do a soft battery reset, you wait for the ECU’s to power down, loose their residual power, kept in capacitors etc etc... Not everyone would understand a hard battery reset! But would negate the need to wait |
5th Oct 2015 10:05am |
Miggit, as i said to Pete above, its a belt & braces thing pal... And when you do an ECU scan and realise there are between 20 & 35 ECU’s in all FF's Could be a VERY costly mistake |
5th Oct 2015 10:11am |
Craig, bud, I understand the belt and braces bit, at the end of the day you is playing with someone elses' ffrr and as a business you have to look after the companies interests, wouldn't want to be explaining why an ECU has stopped working Have you any experience of those de-couplers ?
5th Oct 2015 1:17pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Cheers Craig...
5th Oct 2015 1:32pm |
Pete, for mild steel you should use 5% Co2 95% Argon for metal up to 5mm thick and it used to be 10% and 15 % Co2 for thicker, but I think that they now only have 1 (BOC) they call them Argoshield light (5%) and Heavy , In fact scrub that I've just had a peek and they now do light up to 4 mm, Universal 4 to 10 mm, and heavy 10mm +.
5th Oct 2015 1:49pm |
Pete there's no need to remove the battery connections when your welding your bumper on the bench
5th Oct 2015 1:53pm |
Well I've just had an interesting 10 minutes going through Rave in the Body Repair section, and while it does say to disconnect the negative lead from the battery it does not recommend disconnecting any ECU's, but it does recommenced that the alternator is disconnected in most operations, and waiting 2 minutes before starting
5th Oct 2015 2:53pm |
I'm happy to be corrected by someone more qualified however my understanding is that they act as a surge protector so monitor the voltage for any spikes and cut to a safe level if necessary, so logically the battery would need to be connected. |
5th Oct 2015 5:54pm |
Miggit... Oh I see, I thought if I welded anything that has been anywhere near the fatty I best disconnect the battery....
6th Oct 2015 5:43pm |
You Live Close to the Edge, Pete
6th Oct 2015 9:54pm |
