Home > Technical (L322) > Setting electric steering column into auto mode.
666tur
United Kingdom 2012 Range Rover Vogue SE TDV8 Zambezi Silver
My previous RR steering wheel pulled into dash when ignition went off and back out when on. My latest 2012 does not, it adjusts manually but does not move on parking. The manual refers to a setting that lifts the steering wheel and lowers the drivers seat when opening the door to assist entry/exit, it says the steering adjustment needs to be put in auto mode but it does not say how to do it. Does anyone know how to engage it??
Cheers 2012 4.4TDV8 VSE
2004 TD6 132k miles- SOLD
1995 Land Rover Defender 110 Tithonus Ex Military
1995 Land Rover Discovery 3.9i V8 manual
Post #348669 20th Sep 2015 6:06pm
It's in your driver settings on the dash. I think it's called lazy seats...
Post #348670 20th Sep 2015 6:12pm
does it not set on the drivers seat memory settings....ie , adjust seat steering wheel and seat position to required setting then press the seat memory.. ... - .- -.
Post #348671 20th Sep 2015 6:17pm
oldcro
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
On the steering wheel adjuster, is there an auto and manual switch. If so set to auto.
Post #348672 20th Sep 2015 6:24pm
666tur
Thanks. I will have a look at the menu. There is no button on the column. 2012 4.4TDV8 VSE
Post #348676 20th Sep 2015 7:13pm
oldcro
On the steering column you have an adjusting knob to raise or lower and move in or out, try twisting this knob for auto or manual control.
Post #348681 20th Sep 2015 7:30pm
oldcro
Don't you just love people who ask for help then cannot be bothered to acknowledge those who respond, regardless of whether the replies were helpful or not. Twisted Evil
Post #348975 22nd Sep 2015 5:58pm
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
I've read a few threads on the steering wheel moving out of the way when getting in and out of the car. Mine does not move and looked at the adjustment lever and I've tried to twist it but it doesn't want to twist. Or maybe I'm not trying hard enough. But dont want to break it trying too hard. On the seat bit, sometimes my seat moves down and back and other times it doesn't. Rolling Eyes
Post #349037 22nd Sep 2015 10:52pm
oldcro
I was referring to the information shown in the quick start guide in TOPix under "Comfort Adjustments".
Post #349040 22nd Sep 2015 11:25pm
Weegie
Mine doesn't twist. Pull towards or away for reach and up and down for tilt. Unless it has changed with the later models? John
GAP iiD BT
Post #349046 23rd Sep 2015 6:44am
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
I'm sure I read it got turned off by default around 2007ish because of all the failed adjuster mechanisms
mine is off, not bothered turning it back on
Post #349142 23rd Sep 2015 6:53pm
Your right Katash it did, then became driver programmable from 2009my.... Thumbs Up
Post #349160 23rd Sep 2015 8:59pm
666tur
Thanks for feedback. I tried the lazy exit setting in the tft screen menu and it still doesn't pull the wheel in when the engine is turned off. As my TD6. The manual adjustment does work though. 2012 4.4TDV8 VSE
Post #365963 7th Jan 2016 10:26pm
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
I've also set the lazy exit setting on my 2011 4.4 tdv8 and nothing happens.
I also have an issue with the memory settings not being used when I unlock the car. I have to select the required memory button to get the seat to move to my position after I get in. This did work on my previous L322. Can anyone confirm if it is a dealer setting as the manual makes no mention of it.
Post #376439 8th Mar 2016 8:44pm
TimBobCom
United States 2011 Range Rover Supercharged 5.0 SC V8 Santorini Black
2011 MY
Steering wheel will raise when I turn off ignition and open driver door. The steering wheel does not adjust in towards the dash, but it does raise.
My seat does not move when I turn off ignition and open driver door. But, my seat is already at the lowest position, and back pretty far (I'm 6'2")
On my old 2003 I don't remember the seat ever moving, but the steering wheel went up and in when I shut off the ignition.
Post #376440 8th Mar 2016 9:01pm
