![]() | Home > Technical (L322) > Setting electric steering column into auto mode. |
It's in your driver settings on the dash. I think it's called lazy seats... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
does it not set on the drivers seat memory settings....ie , adjust seat steering wheel and seat position to required setting then press the seat memory.. ... - .- -.
oldcro Member Since: 17 Mar 2012 Location: Shetland Posts: 359 ![]() ![]() ![]() |
On the steering wheel adjuster, is there an auto and manual switch. If so set to auto. |
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 ![]() ![]() ![]() |
Thanks. I will have a look at the menu. There is no button on the column. 2012 4.4TDV8 VSE
On the steering column you have an adjusting knob to raise or lower and move in or out, try twisting this knob for auto or manual control. |
Don't you just love people who ask for help then cannot be bothered to acknowledge those who respond, regardless of whether the replies were helpful or not. |
Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
I've read a few threads on the steering wheel moving out of the way when getting in and out of the car. Mine does not move and looked at the adjustment lever and I've tried to twist it but it doesn't want to twist. Or maybe I'm not trying hard enough. But dont want to break it trying too hard. On the seat bit, sometimes my seat moves down and back and other times it doesn't. |
I was referring to the information shown in the quick start guide in TOPix under "Comfort Adjustments". |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
Mine doesn't twist. Pull towards or away for reach and up and down for tilt. Unless it has changed with the later models? John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
I'm sure I read it got turned off by default around 2007ish because of all the failed adjuster mechanisms
Your right Katash it did, then became driver programmable from 2009my.... |
Thanks for feedback. I tried the lazy exit setting in the tft screen menu and it still doesn't pull the wheel in when the engine is turned off. As my TD6. The manual adjustment does work though. 2012 4.4TDV8 VSE
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
I've also set the lazy exit setting on my 2011 4.4 tdv8 and nothing happens.
TimBobCom Member Since: 18 May 2015 Location: United States Posts: 11 ![]() ![]() ![]() |
2011 MY
