Home > Technical (L322) > Setting electric steering column into auto mode. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
It's in your driver settings on the dash. I think it's called lazy seats... |
20th Sep 2015 6:12pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
does it not set on the drivers seat memory settings....ie , adjust seat steering wheel and seat position to required setting then press the seat memory.. ... - .- -.
20th Sep 2015 6:17pm |
oldcro Member Since: 17 Mar 2012 Location: Shetland Posts: 359 |
On the steering wheel adjuster, is there an auto and manual switch. If so set to auto. |
20th Sep 2015 6:24pm |
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 |
Thanks. I will have a look at the menu. There is no button on the column. 2012 4.4TDV8 VSE
20th Sep 2015 7:13pm |
On the steering column you have an adjusting knob to raise or lower and move in or out, try twisting this knob for auto or manual control. |
20th Sep 2015 7:30pm |
Don't you just love people who ask for help then cannot be bothered to acknowledge those who respond, regardless of whether the replies were helpful or not. |
22nd Sep 2015 5:58pm |
Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284 |
I've read a few threads on the steering wheel moving out of the way when getting in and out of the car. Mine does not move and looked at the adjustment lever and I've tried to twist it but it doesn't want to twist. Or maybe I'm not trying hard enough. But dont want to break it trying too hard. On the seat bit, sometimes my seat moves down and back and other times it doesn't. |
22nd Sep 2015 10:52pm |
I was referring to the information shown in the quick start guide in TOPix under "Comfort Adjustments". |
22nd Sep 2015 11:25pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
Mine doesn't twist. Pull towards or away for reach and up and down for tilt. Unless it has changed with the later models? John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
23rd Sep 2015 6:44am |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
I'm sure I read it got turned off by default around 2007ish because of all the failed adjuster mechanisms
23rd Sep 2015 6:53pm |
Your right Katash it did, then became driver programmable from 2009my.... |
23rd Sep 2015 8:59pm |
Thanks for feedback. I tried the lazy exit setting in the tft screen menu and it still doesn't pull the wheel in when the engine is turned off. As my TD6. The manual adjustment does work though. 2012 4.4TDV8 VSE
7th Jan 2016 10:26pm |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 |
I've also set the lazy exit setting on my 2011 4.4 tdv8 and nothing happens.
8th Mar 2016 8:44pm |
TimBobCom Member Since: 18 May 2015 Location: United States Posts: 11 |
2011 MY
8th Mar 2016 9:01pm |
