![]() | Home > Maintenance & Mods (L322) > Viscous fan conversion |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I haven't got overheating problems as of yet! But I'm not the biggest fan of viscous, as they very regularly seem to half work, i.e. they slip and don't shift all the air that they are supposed to |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8533 ![]() ![]() ![]() |
The temp gauge reads "what the driver expects to see" (same for most cars these days) it will get to normal at around 80deg and then not move of normal until it gets to well over 110deg, this is for the hot running petrol, not sure on the diesel... maybe an idea to stick an actual gauge on the engine and see what it's doing...
Glad you got it sorted..... |
djharm, Have you got any pictures of the install? Yesterday I couldn't spell Engineer... Today I are one!
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
322 Temp gauges are sent the instruction as to what should be displayed by one of the ECU’s (like the BCU for example) so are absolutely NOT showing you what is actually happening with the engine temps! It stops owners complaining about oddities as they used to do in the D1,2 & P38 days... As Pete mentioned, the “normal” temp range runs from about 80 to 120 degree’s! That was also my understanding of the system... |
Right hoe then, mental note to one's self, gauge is as good as a chocolate fire guard |
Never had much success with the fixed temp switches... either comes in too early or late... an adjustable one and you can crank it up a bit if doing towing etc to keep the engine cool rather that waiting for it to get hot.....
Pete, out of interest what have you got yours set on? I can see that it could be an advantage to have it adjustable, but I'm wary about a) the quality of the switches as they are from Ping Pong, b) getting a descent seal between the hose, joiner and capillary pipe, with out crushing the capillary pipe.
Right I've just taken a punt on an adjustable switch, found it on the web, not fleabay, and at £12.95 if it's no good then I haven't wasted too much dosh |
Mine is set to high 90's I'm running an 80deg stat at the moment, Top hose temp normally sits around the 88deg mark but does rise quickly when in traffic...
Kenlow slither? No, cos I haven't got one, but I do know what you mean |
Right I now have everything on its' way, including the Kenlowe seal,
I'll have one off you... PM on way... |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
did you get one of these and can you send me the link as i cant find it anywhere cheers nige |
