Home > Technical (L322) > 6hp26 transmission failure on MY08 tdv8 |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Exactly sir |
8th Jun 2015 10:16pm |
Oh and GOOD LUCK
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Thanks, will have a look this arvo. ______________________________
8th Jun 2015 10:19pm |
Ok an update, I jacked up and turned each wheel while it was in Park. No noises detected anywhere, and front and rear prop shafts turned as normal. Also, when the engine is running and its in Neutral, the transmission makes the same sound as Drive and Reverse. I'm sure it didn't do that on Sunday when we were getting dragged by another car to a safer stopping location. Finally, it now won't let me select Drive if the engine is running. ______________________________
9th Jun 2015 10:49am |
Has anyone had experience fitting a transmission and transfer box from a facelift L322 3.6 tdv8 to an early L322 3.6 tdv8?
10th Jun 2015 7:36am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2494 |
Different canbus protocol in MY10 I suspect and if so then the TCM is not compatible, contrary to my earlier assessment. The mechatronic might be swappable. |
10th Jun 2015 8:24am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1773 |
The above is correct. Same gearbox, but the electronics work on a different CAN-BUS, and not compatible.
10th Jun 2015 8:45am |
Just swapping the TCM and not the valve body is not so straightforward as I understand. A local workshop thought they could put a MY12 6-speed into an early D3 and even after swapping the whole mechatronics still had problems with the box. |
10th Jun 2015 8:57am |
Thanks I forgot about the canbus change. ______________________________
10th Jun 2015 9:10am |
The RR finally went to my usual Indy this arvo.
15th Jun 2015 11:57am |
Fingers crossed here mate. MY 2010 5.0 SC Galway green and sand interior!!
15th Jun 2015 1:13pm |
Thanks. ______________________________
15th Jun 2015 8:32pm |
The mechanic didn't get a proper look at it today. However, he thinks the noise is from the transfer case. And the noise is the gear in between High and Low range. I'll have to have another look at RRPhil's post on the transfer. ______________________________
16th Jun 2015 9:03am |
I think you are on the money Phil. The Indy has ruled out the electrics on the transfer box. The next thing is transfer box out to check the spline. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ______________________________ Vogue tdv8 08MY poverty pack - wow |
22nd Jun 2015 11:46pm |
