Home > Technical (L322) > 6hp26 transmission failure on MY08 tdv8
Page 2 of 5 <12345>
rar110
Ta Cam. I didn't know that. I assumed it has a transmission break. So the purpose it to just find a noise from a CV, diff, or prop shaft? ______________________________
Post #331607 8th Jun 2015 11:07pm
Exactly sir Thumbs Up
Post #331609 8th Jun 2015 11:16pm
Oh and GOOD LUCK Thumbs Up
Hope its an easy cheap fix Confused
Post #331610 8th Jun 2015 11:16pm
rar110
Thanks, will have a look this arvo. ______________________________
Post #331612 8th Jun 2015 11:19pm
rar110
Ok an update, I jacked up and turned each wheel while it was in Park. No noises detected anywhere, and front and rear prop shafts turned as normal. Also, when the engine is running and its in Neutral, the transmission makes the same sound as Drive and Reverse. I'm sure it didn't do that on Sunday when we were getting dragged by another car to a safer stopping location. Finally, it now won't let me select Drive if the engine is running. ______________________________
Post #331643 9th Jun 2015 11:49am
rar110
Has anyone had experience fitting a transmission and transfer box from a facelift L322 3.6 tdv8 to an early L322 3.6 tdv8?
I might have a donor box. ______________________________
Post #331793 10th Jun 2015 8:36am
GraemeS
Australia
Different canbus protocol in MY10 I suspect and if so then the TCM is not compatible, contrary to my earlier assessment. The mechatronic might be swappable.
Post #331800 10th Jun 2015 9:24am
Mikey
The above is correct. Same gearbox, but the electronics work on a different CAN-BUS, and not compatible.
However, if your electronics are OK, then you can (in theory, at least) swap them over int the newer box Thumbs Up
Post #331810 10th Jun 2015 9:45am
GraemeS
Australia
Just swapping the TCM and not the valve body is not so straightforward as I understand. A local workshop thought they could put a MY12 6-speed into an early D3 and even after swapping the whole mechatronics still had problems with the box.
Post #331814 10th Jun 2015 9:57am
rar110
Thanks I forgot about the canbus change. ______________________________
Post #331817 10th Jun 2015 10:10am
rar110
The RR finally went to my usual Indy this arvo.
First impression after hearing the noise was front diff. It makes the noise in neutral so front diff doesn't make sense to me. Will find out more tomorrow maybe when he gets it onto a hoist. A diff sounds cheaper. ______________________________
Post #332588 15th Jun 2015 12:57pm
ebajema
Fingers crossed here mate. MY 2010 5.0 SC Galway green and sand interior!!
Post #332598 15th Jun 2015 2:13pm
rar110
Thanks. ______________________________
Post #332668 15th Jun 2015 9:32pm
rar110
The mechanic didn't get a proper look at it today. However, he thinks the noise is from the transfer case. And the noise is the gear in between High and Low range. I'll have to have another look at RRPhil's post on the transfer. ______________________________
Post #332702 16th Jun 2015 10:03am
rar110
RRPhil wrote:
Would appear to be a transmission issue then, rather than something downstream. It’s just that we’ve had a couple of instances on here of 6HP26’s failing because the output shaft hadn’t apparently been coated with anti-seize grease at the factory and the spline into the transfer box had subsequently failed/worn away through fretting corrosion. Anyway, if your park lock holds then this would rule out this particular cause.
Phil
I think you are on the money Phil.
The Indy has ruled out the electrics on the transfer box. The next thing is transfer box out to check the spline.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  ______________________________
Post #333999 23rd Jun 2015 12:46am
Page 2 of 5 <12345>
