Home > Technical (L322) > Blindspot mirror |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 863 |
Anyone know anything about the 2010 blind spot mirror? It looks like I have this (VSE 2010) as the mirror has the space for the LED but nothing has ever lit up?? It's clearly not working but I've no idea why or where to start looking. I've looked behind the mirror glass and the wiring goes up to the area?
22nd Feb 2015 12:50pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Does yours have vision assist pack? (camera's) |
22nd Feb 2015 1:25pm |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
Hi hoppy_70
22nd Feb 2015 1:27pm |
I s this any help to you:
22nd Feb 2015 1:34pm |
Thanks all. Craig, it doesn't have the vision assist pack, but does have the mirror and wiring. Did they fit this to all cars then, in anticipation of people buying vision pack? Seems wasteful? My Previous RR's!
22nd Feb 2015 3:38pm |
Have you activated it in the menu on the dash by a tick ... ====================================
22nd Feb 2015 4:46pm |
Any help again ?
22nd Feb 2015 5:45pm |
Im not sure Hoppy... I understood the vision assist pack was linked to the blind spot monitoring system and one meant the other etc... I thought the blind spot monitoring used the vision assist camera's to work the system! Please let me know your findings along the way Try as Joker says ticking it in your user display? Or if that does not work find someone to initiate it in the CCF files... Is there any chance the mirrors could have been changed by a previous owner? |
22nd Feb 2015 5:46pm |
happy_70 You should have this on the LCD dash if its fitted - have a look Ours are lit up green on both cars when engine is running. again hope this is of help to you. |
22nd Feb 2015 6:53pm |
Hmmm, that's forward alert?? I have that activated for when the wife isn't In the car (it beeps when you aren't braking fast enough (or at all).
22nd Feb 2015 8:20pm |
happy_70
I think Joker means - the menu stick (selector arm on the steering wheel stalk) for on the LCD display - the menu of the car. Tick = means SELECT IT You should able to choose it from there |
22nd Feb 2015 10:08pm |
happy_70
22nd Feb 2015 10:10pm |
Hi, I'm not getting any LED either stationary or moving. I can't see an option to check or uncheck this, anywhere in the menus. My Previous RR's!
23rd Feb 2015 8:28pm |
jeffw Member Since: 18 Jan 2015 Location: Paddock Wood Posts: 60 |
Do you not need to be in the trade to register on this site? 2011 4.4 TDv8 Vogue SE Zeus Challenger Evo II |
24th Feb 2015 8:33am |
