![]() | Home > Technical (L322) > Blindspot mirror |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 869 ![]() ![]() ![]() |
Anyone know anything about the 2010 blind spot mirror? It looks like I have this (VSE 2010) as the mirror has the space for the LED but nothing has ever lit up?? It's clearly not working but I've no idea why or where to start looking. I've looked behind the mirror glass and the wiring goes up to the area?
Does yours have vision assist pack? (camera's) |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 353 ![]() ![]() ![]() |
Hi hoppy_70
I s this any help to you:
Thanks all. Craig, it doesn't have the vision assist pack, but does have the mirror and wiring. Did they fit this to all cars then, in anticipation of people buying vision pack? Seems wasteful? My Previous RR's!
Have you activated it in the menu on the dash by a tick ... ====================================
Any help again ?
Im not sure Hoppy... I understood the vision assist pack was linked to the blind spot monitoring system and one meant the other etc... I thought the blind spot monitoring used the vision assist camera's to work the system! Please let me know your findings along the way ![]() Try as Joker says ticking it in your user display? Or if that does not work find someone to initiate it in the CCF files... Is there any chance the mirrors could have been changed by a previous owner? |
happy_70 You should have this on the LCD dash if its fitted - have a look Ours are lit up green on both cars when engine is running. again hope this is of help to you.
Hmmm, that's forward alert?? I have that activated for when the wife isn't In the car (it beeps when you aren't braking fast enough (or at all).
happy_70
I think Joker means - the menu stick (selector arm on the steering wheel stalk) for on the LCD display - the menu of the car. Tick = means SELECT IT You should able to choose it from there |
happy_70
Hi, I'm not getting any LED either stationary or moving. I can't see an option to check or uncheck this, anywhere in the menus. My Previous RR's!
jeffw Member Since: 18 Jan 2015 Location: Paddock Wood Posts: 60 ![]() ![]() ![]() |
Do you not need to be in the trade to register on this site? 2011 4.4 TDv8 Vogue SE Zeus Challenger Evo II |
