Home > Technical (L322) > Air Suspention/HDC Inactive. ABS etc
Dazzler
England 2003 Range Rover Vogue Td6 Zambezi Silver
Evening All,
Ongoing problem with Air Suspention Inactive/HDC Inactive. ABS Orange Lights on. Go in to Air Suspention programme on scanner No codes . Go into Dynamic Stability programme it reads up Brakelight switch and Low Voltage. I have changed the Switch and a new battery. I clear the codes all goes away Drive down the road for 3 miles all comes back again Crying or Very sad . Crying or Very sad Crying or Very sad . Plug Scanner back on same codes ???. Any Ideas please, Kind Regards Darren
Post #313973 20th Feb 2015 8:14pm
DMRR
ABS sensor? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #313977 20th Feb 2015 8:41pm
Welshdragon
Might be a long shot as you say ' ABS ' but are all connectors home and rubber boots where should be? ie not getting wet? (or could be the sensor it self)
Only ask as I had a ' check brake pad' issue when going through deep'ish puddles weeks ago, checked the fronts and found the rubber boot had come adrift from the box the connectors are in and got wet, its not happened since either after refitting. ( I was trying to change the lower ball joints at the time hence looking at the fronts. )
yes agree with changing battery as we all know FF's love them!
What codes did you receive?
Im sure someone more knowledgeable will be along soon Thumbs Up If it dont work.......burn it!
Post #313980 20th Feb 2015 8:51pm
You haven't done anything that would put the steering wheel / column off centre by any chance?
Post #313983 20th Feb 2015 8:52pm
Dazzler
No not that I know of. But I did replace rear discs and pads two weeks ago ??? Embarassed
Post #313987 20th Feb 2015 9:10pm
A good chance it is moisture in this multiplug
They get condensation inside them if you don't get the FF nice and warm every day, with your diesel it will be worse than the petrol as the running temp is lower, remove it by pulling the bottom piece of plastic towards the engine and then lift it up, give it and the socket a good blast of contact cleaner, let it dry then fit and remove it several times to polish the contacts, hopefully that will sort it....
Of course it is an FF and yours maybe dong different stuff to mine!!!!! Pete
Post #313989 20th Feb 2015 9:23pm
Dazzler
Sorry to sound Thick Embarassed but do you mean the plug on the ABS Sensors or ABS Unit under the Brake reservoir.
Post #313997 20th Feb 2015 9:51pm
Click where it says "click image to enlarge" don't know why the picture didn't come up...
It's the big plug on the ABS unit that is bolted to the passenger (RHD) inner wing.... Pete
Post #314099 21st Feb 2015 11:12am
pic sorted for you Pete... ... - .- -.
Post #314100 21st Feb 2015 11:13am
Rovertech
United States
Sounds like steering angle sensor. Might try turning the wheel lock to lock, see if it goes away. If the sensor is bad, it'll come back, if not it just needed a good recalibration,
Also you'll probably need to turn the key on for 60 seconds to reset your brake light.
Post #314980 26th Feb 2015 2:29pm
