Home > Technical (L322) > Air Suspention/HDC Inactive. ABS etc |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
ABS sensor? Land Rover Addict
20th Feb 2015 8:41pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Might be a long shot as you say ' ABS ' but are all connectors home and rubber boots where should be? ie not getting wet? (or could be the sensor it self)
20th Feb 2015 8:51pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
You haven't done anything that would put the steering wheel / column off centre by any chance? |
20th Feb 2015 8:52pm |
Dazzler Member Since: 09 Sep 2013 Location: West Sussex Posts: 34 |
No not that I know of. But I did replace rear discs and pads two weeks ago ??? |
20th Feb 2015 9:10pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
A good chance it is moisture in this multiplug
20th Feb 2015 9:23pm |
Sorry to sound Thick but do you mean the plug on the ABS Sensors or ABS Unit under the Brake reservoir. |
20th Feb 2015 9:51pm |
Click where it says "click image to enlarge" don't know why the picture didn't come up...
21st Feb 2015 11:12am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35279 |
pic sorted for you Pete... ... - .- -.
21st Feb 2015 11:13am |
Rovertech Member Since: 25 Feb 2015 Location: Seattle Posts: 20 |
Sounds like steering angle sensor. Might try turning the wheel lock to lock, see if it goes away. If the sensor is bad, it'll come back, if not it just needed a good recalibration,
26th Feb 2015 2:29pm |
