![]() | Home > Maintenance & Mods (L322) > How to remove front wiper arm - Refurb or Replace |
To just remove the wiper arm and replace with the same one or a new one, is a Jaw Gear Puller necessary or will the existing arm just lift off once the main securing nut is undone (this instruction book extract doesn't mention a puller that is pictured below too):
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2275 ![]() ![]() ![]() |
Usually they just pull up but knowing Landrover well anything is possible - as for replacement for me I would replace both as I would always see the repair and then it would prob show up against the other but then they would probably makr the scuttle panel look faded so only solution is a new motor got a spare 100 grand lying around |
Thanks Sandy. Since the initial boredom consumed me, I'd decided to replace for the reasons you mention, so placed a vote to that effect myself and found the how to info... I've not actually found an online video on removing L322 arms but a fair bit of info seems to complicate due to suggesting need for a puller. Other wiper arm removals and videos seem easy: remove nut, lift off arm and replace!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
i removed mine on the td6 and found it was a bit of a |
mogman50 Member Since: 29 Sep 2014 Location: Settle Posts: 37 ![]() ![]() ![]() |
Hi,
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Not sure the 3 arm puller will fit into the available space, might be better with a 2 arm puller
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 ![]() ![]() |
No, the 3-arm puller won't fit! Use a 2-arm puller or as similar to the one shown above. It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
Loosen the nut but leave it on the thread towards the top, lift the wiper blade as high as it goes and gently rock it back & forth... You will here a "gentle pop" put the wiper back down on the screen. unscrew the nut the rest of the way... "A voila!"
i used a large screwdriver to help prise mine off.... ... - .- -.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6746 ![]() ![]() ![]() |
Very subtle there Ryan! CDO! I wonder how many sufferers spotted that! |
Thought he was sysdexlic |
Unfortunately i did ![]() ![]() ![]() |
Thanks for the helpful and humorous replies. Glad I might not need to meddle with a puller, top tip about the masking tape marking and likewise about leaving the nut on whilst starting the arm removal process.
