![]() | Home > Maintenance & Mods (L322) > How to remove front wiper arm - Refurb or Replace |
To just remove the wiper arm and replace with the same one or a new one, is a Jaw Gear Puller necessary or will the existing arm just lift off once the main securing nut is undone (this instruction book extract doesn't mention a puller that is pictured below too):
Jaw Gear Puller:
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2276 ![]() ![]() ![]() |
Usually they just pull up but knowing Landrover well anything is possible - as for replacement for me I would replace both as I would always see the repair and then it would prob show up against the other but then they would probably makr the scuttle panel look faded so only solution is a new motor got a spare 100 grand lying around |
Thanks Sandy. Since the initial boredom consumed me, I'd decided to replace for the reasons you mention, so placed a vote to that effect myself and found the how to info... I've not actually found an online video on removing L322 arms but a fair bit of info seems to complicate due to suggesting need for a puller. Other wiper arm removals and videos seem easy: remove nut, lift off arm and replace!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35629 ![]() ![]() |
i removed mine on the td6 and found it was a bit of a |
mogman50 Member Since: 29 Sep 2014 Location: Settle Posts: 37 ![]() ![]() ![]() |
Hi,
Not sure the 3 arm puller will fit into the available space, might be better with a 2 arm puller
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 ![]() ![]() |
No, the 3-arm puller won't fit! Use a 2-arm puller or as similar to the one shown above. It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Loosen the nut but leave it on the thread towards the top, lift the wiper blade as high as it goes and gently rock it back & forth... You will here a "gentle pop" put the wiper back down on the screen. unscrew the nut the rest of the way... "A voila!"
i used a large screwdriver to help prise mine off.... ... - .- -.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6765 ![]() ![]() ![]() |
Very subtle there Ryan! CDO! I wonder how many sufferers spotted that! |
Thought he was sysdexlic |
Unfortunately i did ![]() ![]() ![]() |
Thanks for the helpful and humorous replies. Glad I might not need to meddle with a puller, top tip about the masking tape marking and likewise about leaving the nut on whilst starting the arm removal process.
