Home > Wheels & Tyres > Largest tyre size to put on 20" rims?
Page 1 of 4 1234>
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
What's the largest size in profile that can be used as I hate thin tyres that make your teeth rattle over British roads, can't understand people with cigarette width paper tyres it's a 4x4 for Gods sake not a cayenne Wink _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #293671 17th Nov 2014 7:33am
ebajema
I agree mate, either stick to the factory size or more sidewall Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #293690 17th Nov 2014 8:40am
johnboyairey
I think this has been asked many times but I think it's 275 45 20 which are often on merc ML's but don't quote me.
Post #293703 17th Nov 2014 10:05am
Vogue
it is 275 45 20 - these are the closest to std OEM. Most 275/45 are slightly less in diameter by a few mm.
However, my General Grabbers were measured when new with a tape around the circumference - they are exactly the same as the Scorpions that came off. The tread depth on the Grabbers was significantly more at 11mm when new hence there being no difference. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #293917 18th Nov 2014 12:35pm
Scottyav
Can you use 55 instead of 45 as i prefer more rubber _____________________________________________________
Post #293923 18th Nov 2014 1:23pm
Vogue
not sure re 275/55 - as it is wider and taller - there may be a clearance issue on the struts. 255/55 are OK AFAIK as many have fitted the 255/55/20 off the L405 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #293933 18th Nov 2014 2:27pm
note that FF rims are 8.5j and RRS rims [which fit the FF] are 9.5j ....i had 295 45 20 tyres on RRS rims fitted to my td6 for quite a while... ... - .- -.
Post #293940 18th Nov 2014 3:32pm
Fit 19's or 18's. They're fab.
Sidewall Appreciation Thread.
Post #294004 18th Nov 2014 6:58pm
BlackPerth
Australia 2017 Range Rover Vogue SE SDV8 Mariana Black
I have Cooper Zeon LTZ on 285/50/20 and they JUST fit. Have been very good on and offroad (quiet too).
cheers 2017 Range Rover Vogue SE SDV8 (with e-diff)
2012 Range Rover Vogue TDV8 Luxury (SOLD)
2010 Land Rover Discovery 4 3.0 TDV6 HSE Stornoway Grey (SOLD)
2006 Land Rover Discovery 3 SE 2.7TDV6 Black, G4 Challenge Copy (gone)
Post #294085 19th Nov 2014 3:34am
ebajema
Not all FFs can go smaller than 20 inch wheels, like my 5.0 for example.
BlackPerth, thanks for that, good to know when I need to update my shoes on the 5.0 Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #294086 19th Nov 2014 3:51am
devonchilliman
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Blackperth...
Did you have any rubbing issues on full lock ?
Post #304700 13th Jan 2015 10:07am
BlackPerth
Nope, none! Very Happy 2017 Range Rover Vogue SE SDV8 (with e-diff)
Post #312552 14th Feb 2015 3:30am
RiccartonRR
285/50R20 gives an outer tyre diameter (according to good old fashioned maths) of 650.8mm
My tyres have an outer diameter of 680.8 so on radius you'll have a spare 15mm to play with. Mine are also 305's so you'll have 20mm extra space in the arches.
I'd go for the 285/50R20 Thumbs Up Sidewall is king Thumbs Up
Post #312566 14th Feb 2015 9:39am
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
What about the speedo readings going bigger? 2004 RR 4.4 V8 Autobiography
Post #318124 15th Mar 2015 9:48am
Mr Tee
275/55/20 on mine, speedo being out is really a myth, maybe by a midge's ball hair but that's it!might be tempted to part with them too, not had a bad winter for a while so they're sat in the garage.....
Post #318127 15th Mar 2015 9:53am
Page 1 of 4 1234>
