Home > Wheels & Tyres > Largest tyre size to put on 20" rims? |
MikeT Member Since: 19 May 2014 Location: Moscow Posts: 87 |
Hi Ian
10th Jan 2016 9:57am |
Hey Graeme
10th Jan 2016 3:23pm |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 |
The width of your wheels is ok for the width of tyres you want to fit .
10th Jan 2016 4:10pm |
I'm struggling to find a supplier for the BFG's here in Russia.
10th Jan 2016 7:29pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2527 |
I had LT245/70R17 Duratracs on my D4. I liked their excellent all-round performance but the tread was a little narrow which gave the impression of exposed sidewalls. However in 255/55R19 the tread is wider than most if not all other brands in this size and gives much better sidewall protection. I haven't seen them in the flesh in 275/55R20 so don't know if the tread is narrow or not. My BFG's tread is wide with a square edge which is excellent for sidewall protection.
10th Jan 2016 7:52pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1387 |
I have 255/55R19 Goodyear Duratracs as my winter tyres and have been pleased with them. Reasonably quiet on the road, fine on ice and snow due to softer compound and reasonably open tread pattern, good on grass and mud, including towing on soft ground, OK braking and steering on road, though obviously less good than OE Continentals. They are LR homologated which should help from an insurance perspective. No experience of BFG alternative, but comparing with Goodyear MT/R which I had before, the Duratracs are much better on road and on ice and harder snow, slightly less good on mud, probably more prone to damage on rocky ground due to softer compound and less reinforced sidewalls, but that is less of an issue for me, so the Duratracs suit me much better. Only Range Rovers since 1988 |
11th Jan 2016 2:00pm |
Hey guys. I can also get Cooper Discoverer A/T3 275/55 R20. What would your opinions be in terms of preferences agains the duratecs?
13th Jan 2016 11:59am |
I know someone who liked the AT3s in 265/60R18 that he had on his D3. |
13th Jan 2016 7:26pm |
I have no experience of the Coopers, but you might like to look at the "cracks in sidewalls" thread on this page and other places. Only Range Rovers since 1988 |
13th Jan 2016 8:32pm |
Thanks for pointing me in the direction of the thread...
13th Jan 2016 9:12pm |
I'd say the Duratrac compound is halfway between a full winter tyre and a summer all terrain, so will not give as much grip in these cold conditions, though their more open tread will help in the snow. You might like to look at Canadian or US reviews for winter performance. If your main focus is on winter road driving, then from comments I have heard, though not personal experience, a full winter tyre like the Vredestein Wintrax or Pirelli Scorpion Winter might be better (LR publish a list of homologated winter tyres, your handbook should say what they are, also searchable online). If you are doing a mix of road and off road and can accept reduced winter performance in order to have better off road grip then the Duratrac is probably better. If you look at the Edfors thread on the "My Range Rover" page, you'll see MT/Rs being replaced with winter tyres for winter in Sweden, maybe similar weather?
14th Jan 2016 1:51pm |
I'll be changing the car in 12 months so I'm only concerned about the rest of this winter season. So probably the Duratecs will be the best option. I understand it's always best to have separate winter and summer tyres in my conditions. I'm just trying to save a bit of cash. I need to replace my tyres so just trying to find the best set that will see me through |
14th Jan 2016 4:19pm |
I presume this bulge comes down from the fuel filler? Is there enough play to be able to screw this back without affecting the fuel pipe? |
17th Jan 2016 9:09am |
I've never done it , but there is info on this thread
17th Jan 2016 2:32pm |
