![]() | Home > Technical (L322) > Headlight Wash+Wipe not working - quick fix needed for MOT |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Only a quick thought - I am sure others who know will be along soon
The mot Inspection Manual states that a headlight wash / wipe system "may" be fitted and if so it must work.
Zain Member Since: 17 Apr 2014 Location: London Posts: 98 ![]() ![]() ![]() |
yes....im thinking along the sames line.....(i never use the system intentionally anyway!) ...but is there a way to blank off where the washer wiper arm protrudes out of the plastic plate (under the headlight) |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7908 ![]() ![]() ![]() |
Xenon lights have to have a wash system by law, as a dirty lens scatters the light inconsistently and dazzles other drivers.
That piece of plastic can be removed, presumably you could remove each of them and stick a piece of plastic on the rear of each of them. Should do for an mot. If you were really adventurous you could then also fill the holes and paint them. |
Not according to the MOT Inspection Manual they don't. |
i was under the impression only IF they are fitted they are a testable item......in all fairness the mot guidelines are not very clear...... |
The is another thread on here about this.
If fitted ? I thought they had to be fitted. Which is why they have them.
not saying anyones wrong as im not 100% sure myself but are there not xenons fitted to cars from circa 2003 that dont have wash/wipe systems in place. How do they get through the MOT then?
From the MOT Inspection Manual
It was def a requirement at the time, along with self levelling suspension or headlight levelling. If wipers not fitted it should have high pressure washer jets.
Ah...... So...... They may be fitted.....
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
Does it not depend on HOW good your mot man is if it fails/passes.....at the end of the day its only a small wiper/washer on the headlight |
