Home > Technical (L322) > Headlight Wash+Wipe not working - quick fix needed for MOT |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Only a quick thought - I am sure others who know will be along soon
28th Oct 2014 3:59pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
The mot Inspection Manual states that a headlight wash / wipe system "may" be fitted and if so it must work.
28th Oct 2014 4:42pm |
Zain Member Since: 17 Apr 2014 Location: London Posts: 98 |
yes....im thinking along the sames line.....(i never use the system intentionally anyway!) ...but is there a way to blank off where the washer wiper arm protrudes out of the plastic plate (under the headlight) |
28th Oct 2014 4:46pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7794 |
Xenon lights have to have a wash system by law, as a dirty lens scatters the light inconsistently and dazzles other drivers.
28th Oct 2014 5:07pm |
That piece of plastic can be removed, presumably you could remove each of them and stick a piece of plastic on the rear of each of them. Should do for an mot. If you were really adventurous you could then also fill the holes and paint them. |
28th Oct 2014 5:11pm |
Not according to the MOT Inspection Manual they don't. |
28th Oct 2014 5:14pm |
i was under the impression only IF they are fitted they are a testable item......in all fairness the mot guidelines are not very clear...... |
28th Oct 2014 5:25pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
The is another thread on here about this.
28th Oct 2014 5:30pm |
If fitted ? I thought they had to be fitted. Which is why they have them.
28th Oct 2014 5:31pm |
not saying anyones wrong as im not 100% sure myself but are there not xenons fitted to cars from circa 2003 that dont have wash/wipe systems in place. How do they get through the MOT then?
28th Oct 2014 5:33pm |
From the MOT Inspection Manual
28th Oct 2014 5:37pm |
It was def a requirement at the time, along with self levelling suspension or headlight levelling. If wipers not fitted it should have high pressure washer jets.
28th Oct 2014 5:43pm |
Ah...... So...... They may be fitted.....
28th Oct 2014 5:46pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Does it not depend on HOW good your mot man is if it fails/passes.....at the end of the day its only a small wiper/washer on the headlight If it dont work.......burn it!
28th Oct 2014 7:02pm |
