Home > Technical (L322) > Headlight Wash+Wipe not working - quick fix needed for MOT
Zain
MOT is due saturday and im going through my checklist. The headlight wash+wipe doesnt seem to work. I admit its something i failed to check when purchasing the car recently. There's also the nozzle jet cap missing on the passenger side. The wiper blades are covered in green algae so im assuming the wash+wipe system hasn't worked for quite a while.
I really dont want to spend a few hundred in repairing/replacing the units as my budget is almost exhausted on replacing the cooling system + a full comprehensive service.
Is there anyway i can remove them and put in a blanking plate/cover in order to pass the MOT?
Any hints/tips/recommendations to resolve this issue would be greatly appreciated.
Post #289372 28th Oct 2014 3:51pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Only a quick thought - I am sure others who know will be along soon
I think they only work when headlights are on and then only every 5th time the windscreen washer is operated. Also I guess fuse is checked etc. Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #289376 28th Oct 2014 3:59pm
The mot Inspection Manual states that a headlight wash / wipe system "may" be fitted and if so it must work.
I might be wrong but if you remove the system completely it isn't fitted and therefore is not a testable item and as such can't be failed for it.
Post #289384 28th Oct 2014 4:42pm
Zain
yes....im thinking along the sames line.....(i never use the system intentionally anyway!) ...but is there a way to blank off where the washer wiper arm protrudes out of the plastic plate (under the headlight)
Post #289385 28th Oct 2014 4:46pm
mjdronfield
Xenon lights have to have a wash system by law, as a dirty lens scatters the light inconsistently and dazzles other drivers.
As above, it only operates every 5th time the windscreen is washed with the lights on.
If you have a cap missing, the water will not be sprayed correctly I don't think.
See how you go, but definately don't remove it.
The facelift cars don't have a wiper as the water is high pressure......
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #289389 28th Oct 2014 5:07pm
That piece of plastic can be removed, presumably you could remove each of them and stick a piece of plastic on the rear of each of them. Should do for an mot. If you were really adventurous you could then also fill the holes and paint them.
Post #289392 28th Oct 2014 5:11pm
Not according to the MOT Inspection Manual they don't.
Post #289393 28th Oct 2014 5:14pm
Zain
i was under the impression only IF they are fitted they are a testable item......in all fairness the mot guidelines are not very clear......
Post #289398 28th Oct 2014 5:25pm
The is another thread on here about this.
My MOT guy wants the wash/wipe to work because of the Xenons
He has only remembered (or bothered with) this on three years out of the last seven, though.
I am with NDFI on this, if Xenons fitted, then the wash/wipe needs to work. .
Post #289400 28th Oct 2014 5:30pm
mjdronfield
If fitted ? I thought they had to be fitted. Which is why they have them.
Has it changed again then ?
http://www.theaa.com/motoring_advice/car-s...;ito=83461
Probably still depends what happens on the day. Don't think mine was checked last time...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #289401 28th Oct 2014 5:31pm
Zain
not saying anyones wrong as im not 100% sure myself but are there not xenons fitted to cars from circa 2003 that dont have wash/wipe systems in place. How do they get through the MOT then?
(just thinking out aloud here........)
Post #289403 28th Oct 2014 5:33pm
From the MOT Inspection Manual
Post #289405 28th Oct 2014 5:37pm
mjdronfield
It was def a requirement at the time, along with self levelling suspension or headlight levelling. If wipers not fitted it should have high pressure washer jets.
BMWs around the time sometimes had washers that popped out from under the light on a bar, squirted, and popped back in, so may look like it doesn't have any fitted.
That said, in my experience, you'd wash the screen, they'd pop out to squirt and then get snapped off by the 120mph wind and fly over the bonnet and roof...... Laughing
I'm no expert on current regs, but it's only just changed if the requirement is different now. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #289406 28th Oct 2014 5:43pm
mjdronfield
Ah...... So...... They may be fitted.....
So I'd imagine it may fail......
Laughing 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #289407 28th Oct 2014 5:46pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Does it not depend on HOW good your mot man is if it fails/passes.....at the end of the day its only a small wiper/washer on the headlight Whistle Wink If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #289422 28th Oct 2014 7:02pm
