Home > Wheels & Tyres > Turned Wheel Nut Help Please!
Page 2 of 3 <123>
Binks, we hold wheel nuts is stock if you are N Bristol based sir Thumbs Up
Post #284731 6th Oct 2014 10:33pm
MARKS2RR
England 2010 Range Rover Vogue 4.4 V8 Santorini Black
just had my tyres replaced yesterday, i always check the tyre pressures and torque of the wheel nuts when i get home.
some of the nuts are swelled, think i will replace them all.
seen some stainless steel ones at the billing show. not cheep, £176+p&p for 16.
check out www.wrington.co.uk
out of stock at moment though for the ones for a 2010 L322
what do you think of them?
Post #284825 7th Oct 2014 12:32pm
if you spend £220 on 20 wheels nuts then you must be nuts.... Twisted Evil ... - .- -.
Post #284831 7th Oct 2014 1:23pm
I would easily spend that much or more to avoid swollen nuts.
Post #284835 7th Oct 2014 1:40pm
maybe, but you wouldnt be to happy when they take your old ones off........ Mr. Green ... - .- -.
Post #284837 7th Oct 2014 1:43pm
No. That's why I wear a scrotum guard.
Post #284838 7th Oct 2014 1:48pm
damn, stumped by the 'scroguard'....
Post #284840 7th Oct 2014 2:03pm
Binks
Craig, Have sent you a pm. Slightly off-topic towards the end there guys!!! The 'monkey' will certainly need a Scroguard when I next see him! TDV8 3.6 2010 Santorini Black / Jet Interior
Series 3 1983 petrol swb hard top Marine Blue/Cream Cab - perfect!
Evoke 2013 (wife's) Santorini black, black leather, huge wheels, all the bits.....lucky girl!
Post #284846 7th Oct 2014 2:43pm
Binks
update!
Meant to update earlier - used a Bosch multitool to cut the cover off the wheelnut which took a while as didn't want to damage wheel. Then put a 21mm socket on and tried to turn it! Ended up with a long pipe on the end of the socket spanner and stood on it.....and had to bounce to get it to move!! Tight! Anyway now all sorted - thanks for the advice guys and check your nuts regularly! Merry Christmas to you all! Binks TDV8 3.6 2010 Santorini Black / Jet Interior
Post #297005 4th Dec 2014 6:04pm
J90
France 2006 Range Rover Vogue Td6 Java Black
Can someone please explain how wheel nuts become 'swollen' and then difficult to remove.
I understand that metal expands with heat and then contracts when cold, so how do the wheel nuts remain swollen after the wheels have not been turning for some time?
Whatever the answer I'm going to change my wheel nuts for some new ones.
Ta. Travelling around in circles again.
Post #297031 4th Dec 2014 8:37pm
Mark L
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
The wheel nuts have a permanently fixed chrome cap for aesthetic purposes.
Over time, moisture gets between the nut itself and this cap, thus creating a very slight swelling.
Nut then becomes very difficult to get a socket onto it.
I've replaced 4 this year for that very reason.
Chrome cap:
The long-term solution:
http://www.wrington.co.uk/landrover%20alloy%20wheel%20nuts.html
Post #297033 4th Dec 2014 8:42pm
dingg1
those prices are a total Censored take
Post #297039 4th Dec 2014 8:53pm
those wrington nuts are lovely but very expensive... ... - .- -.
Post #297040 4th Dec 2014 8:54pm
Mark L
Given the tens of thousands of pounds that is spent on the machinery that produces them, plus the labour to make them and cost of materials, I actually think they're about right. Not forgetting the profit you need to make in order to remain a viable business.
A set of 16 from Land Rover will cost you around £80 (price based on recent purchase experience direct from LR). Mine is a 2010 model and I've replaced 4 so far.
Clearly they're not up to the job in certain climates.
If you've every intention of keeping the vehicle for a long time, they're a justifiable investment, IMO.
They're even more justifiable if you're ever caught at the side of a busy road changing a puncture and NOT having to face the prospect of all the associated hassle of tossing about with badly designed, swollen wheel nuts... In the dark... While it's raining... With your family in the car...
Post #297044 4th Dec 2014 9:07pm
J90
Very Happy Now I understand swollen nuts I'm definitely replacing them! Travelling around in circles again.
Post #297056 4th Dec 2014 9:23pm
Page 2 of 3 <123>
