Home > Wheels & Tyres > Turned Wheel Nut Help Please!
Page 1 of 3 123>
Binks
My local tyre dealer managed to turn one of my wheel nuts completely so it now cannot be removed. Any ideas please? Has this happened to anyone else? Help please! Thanks , John TDV8 3.6 2010 Santorini Black / Jet Interior
Series 3 1983 petrol swb hard top Marine Blue/Cream Cab - perfect!
Evoke 2013 (wife's) Santorini black, black leather, huge wheels, all the bits.....lucky girl!
Post #284633 6th Oct 2014 3:00pm
you could use something like this,
http://www.screwfix.com/p/laser-emergency-...2ecf61c7c5
i'm surprised the tyre chap hasnt got a set of these removal sockets... ... - .- -.
Post #284635 6th Oct 2014 3:20pm
ebajema
There is some nasty "nut grabber" type socket that you can buy at tool shops and maybe Halfords. If you do a little search on the forum you will find it. The posts are about lock wheel nuts if I remember correctly.
Good luck. MY 2010 5.0 SC Galway green and sand interior!!
Post #284636 6th Oct 2014 3:21pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Should it not be down to the tyre dealer to rectify the problem, at their cost!
Post #284637 6th Oct 2014 3:22pm
Binks
Thanks for the replies. Spoke to Duckworth who suggested a 22mm bi-hex socket - whack it on and hope! I will try that first......somewhere on here I did read that the Laser Emergency sockets do not work on these models? but thanks anyway. TDV8 3.6 2010 Santorini Black / Jet Interior
Post #284640 6th Oct 2014 3:48pm
Googsy
Is it the silver cap that's rotating on top of nut? If so use a grips to wiggle off the cap then remove with a 22 mm socket . Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #284642 6th Oct 2014 4:19pm
SO3isme
I discovered that something similar had happened to 8 of my wheel nuts. In my case an over-size socket did the job. I tend to agree that the offending tyre shop should sort this. Dan is good if you want a replacement nut.
Post #284662 6th Oct 2014 6:46pm
Sandyt
+1 think they should be resolving this
Post #284671 6th Oct 2014 7:22pm
I got one off on an old car with an under size socket smashed on with a lump hammer
Socket and nut are useless and both go in the bin once done
Post #284687 6th Oct 2014 8:19pm
Binks
I have ordered a double hex 22m socket and will apply it to the offending nut with more than a little force! Googsy - what has happened is the silver cap has been turned(ie no flats left) through over-zealous torque by the tyre guys. If the silver cap comes off is there a 22mm nut beneath? Can I just cut the cap off?
I agree that they shoudl sort it out too - but having had them do the damage, I am hesitant in asking them to sort it out in case they do more damage like drilling it out, etc.
I will let you know how I get on when the Bi-hex arrives on Wednesday! Thanks for all your comments. TDV8 3.6 2010 Santorini Black / Jet Interior
Post #284691 6th Oct 2014 8:32pm
If its a normal wheel nut (not a LOCKER!!!) then YES under the cap is a 22mm nut so just split & remove the cover and all will be well Thumbs Up
Post #284694 6th Oct 2014 8:43pm
PaulTyrer
If the dipsticks at the tyre dealers did not realise that the silver caps were just caps and not wheel nuts then I would take the car back to them and get them to fix it, then get the prat who did it sacked!
Post #284700 6th Oct 2014 9:05pm
Googsy
If it only the silver cap turning panic over I only replaced 4 such blighters this very day due to them swelling. I use a grips with a clamp on the silver cap to manipulate and pull off it's quite easy. Yes under the cap is a 22 mm Thumbs Up I always carry spare nuts for this very reason. In any case you will be able to use the damaged one until you get a replacement or two. Best buy 10 or so then check and replace as necessary. Site sponsors do them for about 4 quid each go for oem replacements not copies. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #284713 6th Oct 2014 9:38pm
PaulTyrer
Fair enough about the wheel nut caps, but if the tyre dealers (presumably so called 'specialists'), my point is that if they do not realise that they are bolloxing up wheel nut covers what the f**k are they doing employed as tyre fitters
Post #284726 6th Oct 2014 10:23pm
Because most are "Monkeys" paid "peanuts" Whistle Whistle Whistle Rolling Eyes
Post #284730 6th Oct 2014 10:32pm
Page 1 of 3 123>
