![]() | Home > Wheels & Tyres > Turned Wheel Nut Help Please! |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Binks, we hold wheel nuts is stock if you are N Bristol based sir |
MARKS2RR Member Since: 29 Aug 2014 Location: Lancashire Posts: 12 ![]() ![]() ![]() |
just had my tyres replaced yesterday, i always check the tyre pressures and torque of the wheel nuts when i get home.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
if you spend £220 on 20 wheels nuts then you must be nuts.... |
I would easily spend that much or more to avoid swollen nuts. |
maybe, but you wouldnt be to happy when they take your old ones off........ |
No. That's why I wear a scrotum guard. |
damn, stumped by the 'scroguard'....
Binks Member Since: 03 Mar 2012 Location: Bristol Posts: 17 ![]() ![]() ![]() |
Meant to update earlier - used a Bosch multitool to cut the cover off the wheelnut which took a while as didn't want to damage wheel. Then put a 21mm socket on and tried to turn it! Ended up with a long pipe on the end of the socket spanner and stood on it.....and had to bounce to get it to move!! Tight! Anyway now all sorted - thanks for the advice guys and check your nuts regularly! Merry Christmas to you all! Binks TDV8 3.6 2010 Santorini Black / Jet Interior
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 ![]() ![]() ![]() |
Can someone please explain how wheel nuts become 'swollen' and then difficult to remove.
Mark L Member Since: 29 Oct 2014 Location: Tamworth Posts: 121 ![]() ![]() ![]() |
The wheel nuts have a permanently fixed chrome cap for aesthetic purposes.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 ![]() ![]() |
those wrington nuts are lovely but very expensive... ... - .- -.
Given the tens of thousands of pounds that is spent on the machinery that produces them, plus the labour to make them and cost of materials, I actually think they're about right. Not forgetting the profit you need to make in order to remain a viable business.
