Home > Technical (L322) > Reduced Performance |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1463 |
Thanks Baltic Blue, I have the bulletin and it does look a bit involved so I will leave it to a competent garage, probably a main dealer. BMW i3 Electric Car
26th Aug 2018 8:33am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3710 |
I agree totally with NMJ, but I would just add that several plastic plenum manifolds have suffered hair line cracks, which gives the same reduced performance problem.
26th Aug 2018 5:44pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8484 |
^ and what Mike said... There is nothing that can't be fixed with a hammer😜😜
26th Aug 2018 5:47pm |
Hi Guys,
26th Aug 2018 5:58pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
yes driving gently for a few days can cause the oil to build up as NMJ describes.
26th Aug 2018 8:21pm |
Yes I have limited (time) warranty and I can get the work done if it's needed. Ive already sorted a few issues out myself at my expense (towbar wiring, tow bar, parking sensors and a broken wire on air quality sensor) so im sure he will play ball if this work is needed. I'll drive it for a couple of days using the gas pedal a little more just to keep using above 2000 momentarily and see how it goes.
26th Aug 2018 9:02pm |
Greg,
26th Aug 2018 9:15pm |
I have no problem taking car dealers or warranty companies to court, I've done it about 7 or 8 times now and won every time. They'd have a very difficult time in court explaining that blue oil smoke was not a fault especially in the light of the modification kit available from Land Rover to cure the problem. Hopefully it wont come to that if I modify my driving a little.
26th Aug 2018 9:54pm |
Yep. That will do it.
26th Aug 2018 10:53pm |
I went for a little drive this afternoon, about 40 miles round trip, it's very difficult to spend any time North of 2000 RPM. When I did give it some wellie on the way back there was a slight haze of blue smoke that cleared in about 3 seconds. After that when I repeated the boot treatment the exhaust was clear.
27th Aug 2018 3:29pm |
My opinion, for what is worth,
27th Aug 2018 5:32pm |
completely agree with Mike!
27th Aug 2018 7:02pm |
gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158 |
There is a lot to be said for giving your car a regular Italian tune up diesel or not.
30th Aug 2018 10:25pm |
