Home > Technical (L322) > power ratio front/rear
does anyone know the exact diff drive power ratio for front and rear of the FF....i think it might be 40% front and 60% rear.. ... - .- -.
Post #270581 13th Jul 2014 11:33am
50/50 apparently..
Post #270596 13th Jul 2014 1:08pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Stan.....whats the Haldex for then??....not sure if its true on not but the stealers told me the FF is front wheel drive in normal use (100/0) then when slippage is detected the haldex motor engages the lock clutch to send drive to the rear wheels as well (50/50)....cost me £400 to have a duff haldex swapped last year....have I been told a lie? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #270601 13th Jul 2014 2:10pm
no idea what that is paul...
my extract is from the WM.. ... - .- -.
Post #270602 13th Jul 2014 2:13pm
googled it and its some kind of power transfer when it detects a wheel slip, so if the osf has no traction all the power goes to the other three wheels. ... - .- -.
Post #270603 13th Jul 2014 2:16pm
paulmoran2
Think its item 2 on the drawing..Haldex AKA ETM ..Page 293 in the WM..seems your answer is about right Stan
Post #270605 13th Jul 2014 2:22pm
sounds like a justified expense then paul.. ... - .- -.
Post #270614 13th Jul 2014 3:18pm
mzplcg
The Haldex is only on those cars with the active rear diff. It's the bit which does side to side lock up / Variable Limited Slip functions effectively. If you want to know more about Haldex stuff check out any 4WD Volkwagen. The Golf / Passat / Jetta etc all used Haldex units to very good effect.
Post #270619 13th Jul 2014 4:10pm
Philip
All (proper) Range Rovers have a full-time 50/50 torque split - can't believe a dealer could get it that wrong.
Electronic rear diff is not part of a Haldex system - it's a multi-plate diff locked via an electric motor.
Edit - pre-2006-facelift cars have the NV225 transfer box, not Magna-Steyr,. Still 50/50 torque split, but with only a 50% locking effect for the centre diff.
Post #270660 13th Jul 2014 8:13pm
TugRR
^ +1 Haldex coupling is nothing like - bloody amateurs Rolling Eyes
Thumbs Up Where do you go after one of these . . . ?
Post #270661 13th Jul 2014 8:24pm
paulmoran2
Thats Farnell Landrover Leeds for ya.....I had an odd vibration when tight cornering and they stuck on the diagnostic and found the ETM motor had an error. They then said it was locking the rear wheels together (as one axle) so it needed a new ETM motor which they called it "A Haldex Motor"....wasnt covered under the LR extended warranty so I had to lay out for it Big Cry GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #270700 14th Jul 2014 7:21am
paulmoran do you definitely know if your car has the locking rear diff? very very unusual for a desiesal to have it fitted.
If not you dealer has been staling from you because the standard diff is open with no clutches Haldex or otherwise and certainly no motor,
edit ; I just thought if you centre diff locked up it would make the car judder in slow tight corners but the explanation you got is still B/S 2008 MY Supercharged
Post #270727 14th Jul 2014 10:25am
Philip
Suspect it's a rare option - can presumably be identified from the VIN or by sticking your head underneath (it's not difficult to spot the motor on a Discovery diff).
Post #270729 14th Jul 2014 10:33am
paulmoran2
@ Axle..just checked the build sheet and yes..>>
Vehicle Information
Catalogue: RANGE ROVER (D4) 2002-2009
VIN: SALLMAM238AXXXX
Date: 20/05/2014
Time: 15:22:37
Build date: 14/08/2007 Registration: V5RTE
Minor Features
Rear Axle Locking Differential
Think the cornering issue i had was because the rear axle would lock up as one solid axle (due to the ETM motor fault) which is only supposed to happen when one wheel slips?. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #270744 14th Jul 2014 11:39am
Coal burner+Locking rear diff=ultimate off roader Thumbs Up 2008 MY Supercharged
Post #270917 15th Jul 2014 2:21am
