Home > Technical (L322) > ffrr error codes p0120 & p0221 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35217 |
no luck on rangerovers.net then...
10th Jul 2014 4:55pm |
Rrkev Member Since: 06 Jul 2013 Location: Gloucester Posts: 5 |
no luck over there, have checked the wiring from the throttle body to the ecu, with a multimeter i have 0.1 ohm resistance on all wires, i have also checked the blue wire for ground which has been a few issues noted but blue wire to neg battery terminal (with loom connected to ecu) 0.1 ohm resistance also |
10th Jul 2014 6:02pm |
fenlander Member Since: 14 Jan 2020 Location: Norfolk Posts: 124 |
A very old thread, did the OP ever solve this issue?
23rd Jul 2020 8:24pm |
Yes I did fix it, turns out the e-box fan failed which resulted in the engine ecu going faulty. I lubed the ebox fan, bought a replacement ecu and had it programmed and the cars been fine since |
23rd Jul 2020 9:05pm |
Great to hear you sorted the problem and thanks for your reply .
23rd Jul 2020 9:26pm |
E-box fan is located in the bottom of the big black box under the bonnet, simply remov the lid, pull the ecus and their carrier out, and fan is towards the front of the box, it will have a plastic casing. Just open it up give it 12v and spray the spindle with wd40 |
23rd Jul 2020 9:32pm |
