Home > Technical (L322) > ffrr error codes p0120 & p0221
Rrkev
United Kingdom 2003 Range Rover Vogue 4.4 V8 Oslo Blue
hi all ripping my hair out with my latest ffrr fault, it's a 2003 4.4 v8 l322, driving home the other night i let my foot off the accelerator and ping! engine failsafe mode, drove a bit further let foot off again and ping!, air suspension inactive, hdc inactive, engine check light, abs warning light, brake warning light, but car drives absolutly fine no loss of power, it is bringing up these faults on petrol & lpg, and after switching the ignition on the engine does not need to be running to bring the errors up, on reading the codes po120 & po221 throttle potetiometer clear the code it comes straight back so far i have done the following.
check battery getting 12.5 volts after being stood overnight
check alternator charging at 14.1 volts
changed accelerator pedal (2 different units)
checked air filter
cleaned throttle body
checked wiring from throttle body back to ecu
with theair intake pipe off, checked throttle operation and all seems fine
checked thermostat heater
so far none of the above has cleared this error or found any faults i'm now thinking maybe maf or throttle body itself, error only shows itself when throttle at fully closed position below is some live dats i've taken using hawkeye to try and identify the problem. readings were taken at tickover. any help appreciated.
Range rover live data
error codes
Throttle potentiometer 2
Live data
Eng speed fluctuates from 576-630
Eng spec speed 600
Coolant temp 95c
Rad cool temp 52c
Intake air temp 43c
Air mass 18.9-19.2 kg/h
Timing 189.5 kW
Inj time 3.8 ms
Throttle pos 1%
Battery 13.8 volts
Throttle pot1 .59v. Ful throttle 4.36
Throttle pot2 1.53v full throttle .37 volt
Pedal trav sens 1 .33v full throttle 2.31v
Pedal trav sens 2 .65v full throttle 4.66v
Post #270141 10th Jul 2014 4:33pm
no luck on rangerovers.net then...
googling comes up with problems with the wiring going to the throttle body.. ... - .- -.
Post #270146 10th Jul 2014 4:55pm
Rrkev
no luck over there, have checked the wiring from the throttle body to the ecu, with a multimeter i have 0.1 ohm resistance on all wires, i have also checked the blue wire for ground which has been a few issues noted but blue wire to neg battery terminal (with loom connected to ecu) 0.1 ohm resistance also
Post #270152 10th Jul 2014 6:02pm
fenlander
England 2002 Range Rover SE 4.4 V8 Tonga Green
A very old thread, did the OP ever solve this issue?
Yes got same model and same issues Sad "Gloria" 2002 L322 Voguish V8 LPG - carcass
"Jessica" 1996 Disco 1 300 TDi Auto
"Harriet" 1994 Disco 1 300 TDi Manual - Gone
"Daisy" 1992 Disco 1 200 TDi Manual - Gone
Post #562451 23rd Jul 2020 8:24pm
Rrkev
Yes I did fix it, turns out the e-box fan failed which resulted in the engine ecu going faulty. I lubed the ebox fan, bought a replacement ecu and had it programmed and the cars been fine since
Post #562455 23rd Jul 2020 9:05pm
fenlander
Great to hear you sorted the problem and thanks for your reply .
So what is an e-box fan and where is it located?
cheers "Gloria" 2002 L322 Voguish V8 LPG - carcass
Post #562459 23rd Jul 2020 9:26pm
Rrkev
E-box fan is located in the bottom of the big black box under the bonnet, simply remov the lid, pull the ecus and their carrier out, and fan is towards the front of the box, it will have a plastic casing. Just open it up give it 12v and spray the spindle with wd40
Post #562460 23rd Jul 2020 9:32pm
