![]() | Home > Technical (L322) > Td6 Won't Start |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
quite interesting story
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
My £1 bet goes on the fuel pump for what its worth... Exactly the usual symptoms... |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 ![]() ![]() |
If its the pump - how does one know? The fuel pressure is good and the pump is making noise. |
You only need to be a couple of lb under pressure and it won't start! Will run all day long once started (ie on easy start) |
Right Guys.
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Mine wouldn't start last year for exactly the same reason - dodgy injector. |
