Home > Technical (L322) > Td6 Won't Start
theanswers
Ireland
Td6 Won't Start
Hello Guys.
More bother, sometimes I do lose patience with these land rovers.
For the past 3 weeks I've been unable to start my td6. Fuel pressure looks good, no bubbles in the lines. However - it turns and turns but wont start. Sometimes previously, when hot I would have the same issue, but eventually it would start. Always started when cold until 3 weeks ago.
Starts perfect now with easy start and runs fine.
What do you think? Really sorry asking for all this help. I'm really consider moving back to the landcrusier.
Post #269652 8th Jul 2014 11:36am
Fuel pump at rear wheel on its way out
Post #269655 8th Jul 2014 11:51am
theanswers
Ireland
How can we be sure? The garage checked the fuel pressures and he said they were perfect.
Post #269656 8th Jul 2014 11:56am
Mr Tee
Sounds like an injector could be at fault, had the exact same, cranking on key for about 30 secs then away.
Post #269700 8th Jul 2014 3:52pm
Joncey
Jersey 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
I will say fuel pump .
Mine had the same symptoms at the start of May the first sign that something was wrong was it was very hard to start when hot this went on for a few days but it would start fine in the morning.
Then about 4 days in it just stopped altogether and would not start at all .
It turned out that my tank fuel pump had failed the nice people at the deal claimed and replaceed both pumps under the extended warranty Smile as they said it was only going to be a matter of time before the inline one gives up as well and the warranty people agree with them Thumbs Up
Post #269702 8th Jul 2014 3:54pm
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
had same problem myself soon after getting car ,turned out to be key had lost programing or something like that ,my lad had been messing about with hawkeye and goofed it up ,trip to independents and all sorted have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #269714 8th Jul 2014 5:24pm
theanswers
Ireland
Hey Guys.
Still no luck. I've ordered the rear wheel fuel pump. The garage has also replaced number 5 injector with a spare, as this one had limited leakage. The garage is committed that there is enough fuel pressure. Anyway to test the intank pump, maybe rattle it or something? When one turns the key you can hear both pumps running and fuel line moves with the pressure.
Apart from that anything else I should check. Would it be lack of voltage to the starter?
Is there any sensor which would prevent the car from starting? I'm really get fed up. She's been refusing to start for the best part of three weeks.
Sad
Post #270179 10th Jul 2014 8:49pm
Sounds like you need a better garage.
Post #270185 10th Jul 2014 9:03pm
theanswers
Ireland
The individual is very capable, however himself and myself have been extremely busy over the passed number of weeks so It's hard to get time. However - both of us are struggling because the injectors are good; showing no faults. the one which was slightly bad was replaced, the fuel pressure is good and the starter is turning perfectly.
Post #270188 10th Jul 2014 9:07pm
adigorn
Can you describe the way you tested injectors?
Post #270192 10th Jul 2014 9:23pm
theanswers
Ireland
He did it using a kit. Placed the return or something into jars. Number five was releasing fuel, not a lot - however we replaced it because I had a spare engine. Is this the correct method?
Post #270194 10th Jul 2014 9:34pm
adigorn
leak off only tests overflow
injector can leak internally as well and loosing pressure
they need to be removed and tested
You also said the pressures are good have you checked HI pressure on startup?
Post #270195 10th Jul 2014 9:44pm
theanswers
Ireland
No, Once the car starts it run perfectly. We have not removed and tested the injectors. It's looking like we may have too.
Which pump is the high pressure? The in tank or external one? I've ordered the external one.
Post #270196 10th Jul 2014 9:47pm
theanswers
Ireland
It only starts currently with easy start.
Post #270197 10th Jul 2014 9:48pm
adigorn
Hi pressure one is the mechanical one driven by timing chain
If you have leaking injector it will run ok when started
(starting from easy start excludes problem with crank/cam sensors)
I d be looking hi pressure problem (pump or injectors)
Considering "high" quality of Irish fuel (had LR garage in Waterford for years Thumbs Up )
Post #270198 10th Jul 2014 9:56pm
