Home > Maintenance & Mods (L322) > Which ceramic paste or copper grease?
pld118
Hi,
I've read on the forum that some people prefer copper grease, others prefer a different product for their brake pads, such as ceramic compound but aside to copper grease, I've yet to see any named brand products.
Our recently fitted front Brembo pads are going to be removed to be cleaned and re-coated to try and eradicate a very annoying squeal (the fitting mechanic didn't use the AF supplied copper grease but used his own normal grease, so don't yet know if that's the reason for squeal).
I wondered what peoples best recommended product is please (car has front Brembo calipers, discs and pads)?
Thanks
Post #267018 24th Jun 2014 4:56am
mzplcg
I always use coppaslip, the branded one. But I will say that just about all brake squeals I've ever come across were due to pads being replaced without cleaning all the old congealed brake dust off the calipers and carrier brackets. i.e. remove old pads and shove new ones in. Job done. (half done actually)
10 minutes per corner with an assortment of scrapers and wire brushes pays dividends all round. Thumbs Up
Post #267030 24th Jun 2014 7:17am
pld118
Thanks mzplcg.
Never having done anything like that before, what's the best procedure/ product for cleaning off the calipers and carriers please?
Also, when you say branded copper grease, do you mean for example one of these two products?
Post #267034 24th Jun 2014 7:41am
The best procedure would be to return it to the garage that fitted them i would think! Or have i missed something in this story?
Post #267035 24th Jun 2014 7:48am
pld118
If it's a relatively straightforward task, I'm contemplating doing it myself so as to learn. If not and/ or if that doesn't cure the squeal, then I'll take if back.
Post #267037 24th Jun 2014 7:53am
mzplcg
Copaslip, made by the same folks as make Molyslip.
http://www.amazon.co.uk/100G-TUBE-COPASLIP...s=copaslip
That's what I use but I guess they're all fairly similar.
Dom.
Post #267038 24th Jun 2014 8:11am
The problem i can see is once you have tried getting rid of the squeal, you will probably be blamed by the garage you have used for (interfering/creating) the squeal... If you have paid this garage to fit your brakes, simply take it back to them and ask them to take a look?
Post #267041 24th Jun 2014 8:25am
i think it was a friend that fitted them craig..ryan?
it could be the paste that was supplied by AF that is the problem...my son said he didnt think much of the product and used 'proper' [as he calls it] bmw stuff.. ... - .- -.
Post #267043 24th Jun 2014 8:27am
pld118
Yes. Stan/ Craig, it was a family friend mechanic who fitted the brakes.
For clarity, whatever is causing the front squeal it is nothing to do with the copper grease supplied in the Advanced Factors brake kit because on the front brakes, said friend used grease that his garage uses.
He'll take the car back in and look at it no problems, but I'd just like to learn how to do straightforward tasks (if it is) as I go along, time permitting. If my DIY efforts don't change anything, then our friend can have another look.
Thanks all/ Dom Thumbs Up
Post #267051 24th Jun 2014 9:17am
Ahh, now that makes more sense sir... Forgive my earlier post then "just didn't want you to fall foul by tinkering yourself" Thumbs Up
Post #267053 24th Jun 2014 9:31am
pld118
Nothing to forgive, that's a reason why I posted, so that learned members can either supportively say go for it or... Stop and think before you jump in with both feet!
Thank you Thumbs Up
Post #267055 24th Jun 2014 9:53am
Thumbs Up Bow down Thumbs Up
Post #267058 24th Jun 2014 10:08am
mzplcg
Definitely a DIY task these days. And one I will only do myself or use a 100% trusted garage for TBH.
I've actually had a situation where my Ford Granada from years ago had a pad fall out whilst I was reversing into a parking space. The main dealer mechanic had forgotten to refit the retaining pins apparently. I kid you not. Since then I've never really trusted anyone with my brakes except me, or our local garage who knows how paranoid/OCD I am about brakes. He leaves the wheels off for me to inspect usually Laughing
Most garages are fine, I just managed to find one who wasn't. It was a long time ago and they went out of business (surprisingly) after a couple of fairly high profile cases of them charging for stuff not actually done. Trading standards and court cases etc.
But, knowing how to do it yourself means you can, or you can at least do meaningful checks on garage work. You might like to know the below image is of a pad which was reported to me as being “Red – Dangerously Low, 2mm” by a main dealer. This was emailed to their DP and head office with a fairly strongly worded bunch of text and has now been “Dealt with”. But that spanner man will end up in another garage someplace so the world isn't actually rid of him, just the place where he used to work.
Post #267068 24th Jun 2014 10:42am
I got something quite different from my Audi indie when buying some replacement (Audi) pads from them, more like a non setting glue type stuff - "something lube" - can't remember right now but will report later today (after England lose to Costa Rica)
"plastilube"
In a red and white tube .
Post #267110 24th Jun 2014 2:35pm
pld118
Thanks Joe, the plastilube seems rated on German marques for sure and seems to come In red/ white and also blue/white tube Thumbs Up
I've also read a fair few online votes for using Mercedes Benz brake paste on Range Rover brake pads which many say is excellent for anti squeal.
It's about £1.99 for enough to do 1 or 2 'wheels' subject to your preference to use one packet per wheel or spread it a little thinner and use one packet for 2 wheels Mr. Green
Has anyone used it?
http://www.ebay.co.uk/itm/Mercedes-Benz-Br...1351316217
Post #267757 28th Jun 2014 8:56am
