![]() | Home > Maintenance & Mods (L322) > Which ceramic paste or copper grease? |
I always use coppaslip, the branded one. But I will say that just about all brake squeals I've ever come across were due to pads being replaced without cleaning all the old congealed brake dust off the calipers and carrier brackets. i.e. remove old pads and shove new ones in. Job done. (half done actually)
Thanks mzplcg.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
The best procedure would be to return it to the garage that fitted them i would think! Or have i missed something in this story? |
If it's a relatively straightforward task, I'm contemplating doing it myself so as to learn. If not and/ or if that doesn't cure the squeal, then I'll take if back.
Copaslip, made by the same folks as make Molyslip.
The problem i can see is once you have tried getting rid of the squeal, you will probably be blamed by the garage you have used for (interfering/creating) the squeal... If you have paid this garage to fit your brakes, simply take it back to them and ask them to take a look? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35663 ![]() ![]() |
i think it was a friend that fitted them craig..ryan?
Yes. Stan/ Craig, it was a family friend mechanic who fitted the brakes.
Ahh, now that makes more sense sir... Forgive my earlier post then "just didn't want you to fall foul by tinkering yourself" |
Nothing to forgive, that's a reason why I posted, so that learned members can either supportively say go for it or... Stop and think before you jump in with both feet!
Definitely a DIY task these days. And one I will only do myself or use a 100% trusted garage for TBH.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
I got something quite different from my Audi indie when buying some replacement (Audi) pads from them, more like a non setting glue type stuff - "something lube" - can't remember right now but will report later today (after England lose to Costa Rica)
Thanks Joe, the plastilube seems rated on German marques for sure and seems to come In red/ white and also blue/white tube |
